Datasheet AD8421 (Analog Devices) - 2
Description3 nV /√Hz, Low Power Instrumentation Amplifier
Pages / Page29 / 2 — AD8421* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
File Format / SizePDF / 682 Kb
AD8421* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. REFERENCE MATERIALS. Technical Articles
AD8421* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS REFERENCE MATERIALS Technical Articles
View a parametric search of comparable parts.
Technical Articles
• Simple Discrete SE-to-Differential Precision In-amp Circuit:
EVALUATION KITS
High Common Mode Input Range and 50% Less Power • AD62x, AD822x, AD842x Series InAmp Evaluation Board • Use a PGIA to Avoid Getting Burned by Switch Parasitics
DOCUMENTATION DESIGN RESOURCES Application Notes
• AD8421 Material Declaration • AN-1264: Precision Signal Conditioning for High • PCN-PDN Information Resolution Industrial Applications • Quality And Reliability • AN-1401: Instrumentation Amplifier Common-Mode • Symbols and Footprints Range: The Diamond Plot
Data Sheet DISCUSSIONS
• AD8421-DSCC: Military Data Sheet View all AD8421 EngineerZone Discussions. • AD8421-EP: Enhanced Product Data Sheet • AD8421: 3 nV/√Hz, Low Power Instrumentation Amplifier
SAMPLE AND BUY
Data Sheet Visit the product page to see pricing options.
Technical Books
• A Designer's Guide to Instrumentation Amplifiers, 3rd
TECHNICAL SUPPORT
Edition, 2006 Submit a technical question or find your regional support number.
TOOLS AND SIMULATIONS
• AD8421 SPICE Macro Model
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
Document Outline FEATURES APPLICATIONS PIN CONNECTION DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS AR AND BR GRADES ARM AND BRM GRADES ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION ARCHITECTURE GAIN SELECTION RG Power Dissipation REFERENCE TERMINAL INPUT VOLTAGE RANGE LAYOUT Common-Mode Rejection Ratio over Frequency Power Supplies and Grounding Reference Pin INPUT BIAS CURRENT RETURN PATH INPUT VOLTAGES BEYOND THE SUPPLY RAILS Input Voltages Beyond the Maximum Ratings RADIO FREQUENCY INTERFERENCE (RFI) CALCULATING THE NOISE OF THE INPUT STAGE Source Resistance Noise Voltage Noise of the Instrumentation Amplifier Current Noise of the Instrumentation Amplifier Total Noise Density Calculation APPLICATIONS INFORMATION DIFFERENTIAL OUTPUT CONFIGURATION DRIVING AN ADC OUTLINE DIMENSIONS ORDERING GUIDE
