Datasheet AD8421-EP (Analog Devices) - 7
Description3 nV /√Hz, Low Power Instrumentation Amplifier
Pages / Page20 / 7 — Enhanced Product. AD8421-EP. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. …
File Format / SizePDF / 505 Kb
Enhanced Product. AD8421-EP. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. –IN. +VS. RG 2. VOUT. RG 3. REF. +IN. –VS. TOP VIEW. (Not to Scale)
Enhanced Product AD8421-EP PIN CONFIGURATION AND FUNCTION DESCRIPTIONS –IN +VS RG 2 VOUT RG 3 REF +IN –VS TOP VIEW (Not to Scale)
Enhanced Product AD8421-EP PIN CONFIGURATION AND FUNCTION DESCRIPTIONS AD8421-EP –IN 1 8 +VS RG 2 7 VOUT RG 3 6 REF +IN 4 5 –VS
2 00
TOP VIEW
9-
(Not to Scale)
13 1 1 Figure 3. Pin Configuration
Table 4. Pin Function Descriptions Pin No. Mnemonic Description
1 −IN Negative Input Terminal. 2, 3 RG Gain Setting Terminals. Place resistor across the RG pins to set the gain. G = 1 + (9.9 kΩ/RG). 4 +IN Positive Input Terminal. 5 −VS Negative Power Supply Terminal. 6 REF Reference Voltage Terminal. Drive this terminal with a low impedance voltage source to level shift the output. 7 VOUT Output Terminal. 8 +VS Positive Power Supply Terminal. Rev. 0 | Page 7 of 20 Document Outline Features Enhanced Product Features Pin Connection Diagram General Description Revision History Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Outline Dimensions Ordering Guide
