Datasheet AD8227 (Analog Devices) - 5
DescriptionWide Supply Range, Rail-to-Rail Output Instrumentation Amplifier
Pages / Page25 / 5 — AD8227. Test Conditions/. A Grade. B Grade. Parameter Comments. Min. Typ. …
File Format / SizePDF / 527 Kb
AD8227. Test Conditions/. A Grade. B Grade. Parameter Comments. Min. Typ. Max. Unit
AD8227 Test Conditions/ A Grade B Grade Parameter Comments Min Typ Max Unit
link to page 5 link to page 5 link to page 5 link to page 21
AD8227 Test Conditions/ A Grade B Grade Parameter Comments Min Typ Max Min Typ Max Unit
DYNAMIC RESPONSE Small Signal −3 dB Bandwidth G = 5 250 250 kHz G = 10 200 200 kHz G = 100 50 50 kHz G = 1000 5 5 kHz Settling Time 0.01% 10 V step G = 5 14 14 μs G = 10 15 15 μs G = 100 35 35 μs G = 1000 275 275 μs Slew Rate2 G = 5 to 100 0.8 0.8 V/μs GAIN3 G = 5 + (80 kΩ/RG) Gain Range 5 1000 5 1000 V/V Gain Error VOUT = −10 V to +10 V G = 5 0.04 0.02 % G = 10 to 1000 0.3 0.15 % Gain Nonlinearity VOUT = −10 V to +10 V G = 5 RL ≥ 2 kΩ 10 10 ppm G = 10 RL ≥ 2 kΩ 15 15 ppm G = 100 RL ≥ 2 kΩ 15 50 ppm G = 1000 RL ≥ 2 kΩ 750 150 ppm Gain vs. Temperature TA = −40°C to +125°C G = 5 5 5 ppm/°C G > 5 −100 −100 ppm/°C INPUT VS = ±1.5 V to +36 V Impedance Differential 0.8||2 0.8||2 GΩ||pF Common Mode 0.4||2 0.4||2 GΩ||pF Operating Voltage Range4 TA = +25°C −VS − 0.1 +VS − 0.8 −VS − 0.1 +VS − 0.8 V TA = +125°C −VS − 0.05 +VS − 0.6 −VS − 0.05 +VS − 0.6 V TA = −40°C −VS − 0.15 +VS − 0.9 −VS − 0.15 +VS − 0.9 V Overvoltage Range TA = −40°C to +125°C +VS − 40 −VS + 40 +VS − 40 −VS + 40 V OUTPUT Output Swing RL = 10 kΩ to ground TA = −40°C to +85°C −VS + 0.2 +VS − 0.2 −VS + 0.2 +VS − 0.2 V TA = +85°C to +125°C −VS + 0.2 +VS − 0.3 −VS + 0.2 +VS − 0.3 V RL = 100 kΩ to ground TA = −40°C to +125°C −VS + 0.1 +VS − 0.1 −VS + 0.1 +VS − 0.1 V Short-Circuit Current 13 13 mA POWER SUPPLY Operating Range Dual-supply operation ±1.5 ±18 ±1.5 ±18 V Quiescent Current TA = +25°C 350 425 350 425 μA TA = −40°C 250 325 250 325 μA TA = +85°C 450 525 450 525 μA TA = +125°C 525 600 525 600 μA TEMPERATURE RANGE −40 +125 −40 +125 °C 1 The input stage uses pnp transistors, so input bias current always flows into the part. 2 At high gains, the part is bandwidth limited rather than slew rate limited. 3 For G > 5, gain error specifications do not include the effects of External Resistor RG. 4 Input voltage range of the AD8227 input stage. The input range depends on the common-mode voltage, differential voltage, gain, and reference voltage. See the Input Volt sectio age Range n for more information. Rev. 0 | Page 4 of 24 Document Outline FEATURES APPLICATIONS PIN CONFIGURATION GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION ARCHITECTURE GAIN SELECTION REFERENCE TERMINAL INPUT VOLTAGE RANGE LAYOUT Common-Mode Rejection Ratio over Frequency Power Supplies References INPUT BIAS CURRENT RETURN PATH INPUT PROTECTION RADIO FREQUENCY INTERFERENCE (RFI) APPLICATIONS INFORMATION DIFFERENTIAL DRIVE Tips for Best Differential Output Performance PRECISION STRAIN GAGE DRIVING AN ADC OUTLINE DIMENSIONS ORDERING GUIDE
