Datasheet AD8290 (Analog Devices) - 2
DescriptionG = 50, CMOS Sensor Amplifier with Current Excitation
Pages / Page21 / 2 — AD8290* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
File Format / SizePDF / 478 Kb
AD8290* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. DESIGN RESOURCES. DOCUMENTATION. Data Sheet
AD8290* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS DESIGN RESOURCES DOCUMENTATION Data Sheet
View a parametric search of comparable parts. • AD8290 Material Declaration • PCN-PDN Information
DOCUMENTATION
• Quality And Reliability
Data Sheet
• Symbols and Footprints • AD8290: G = 50, CMOS Sensor Amplifier with Current Excitation Data Sheet
DISCUSSIONS Technical Books
View all AD8290 EngineerZone Discussions. • A Designer's Guide to Instrumentation Amplifiers, 3rd Edition, 2006
SAMPLE AND BUY
Visit the product page to see pricing options.
REFERENCE MATERIALS Technical Articles TECHNICAL SUPPORT
• Auto-Zero Amplifiers Submit a technical question or find your regional support • High-performance Adder Uses Instrumentation Amplifiers number.
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION AMPLIFIER HIGH POWER SUPPLY REJECTION (PSR) AND COMMON-MODE REJECTION (CMR) 1/f NOISE CORRECTION CURRENT SOURCE APPLICATIONS INFORMATION TYPICAL CONNECTIONS CURRENT EXCITATION ENABLE/DISABLE FUNCTION OUTPUT FILTERING CLOCK FEEDTHROUGH MAXIMIZING PERFORMANCE THROUGH PROPER LAYOUT POWER SUPPLY BYPASSING DUAL-SUPPLY OPERATION PRESSURE SENSOR BRIDGE APPLICATION TEMPERATURE SENSOR APPLICATION ADC/MICROCONTROLLER OUTLINE DIMENSIONS ORDERING GUIDE
