Datasheet AD8251 (Analog Devices) - 2
Description10 MHz, G = 1, 2, 4, 8 iCMOS Programmable Gain Instrumentation Amplifier
Pages / Page25 / 2 — AD8251* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionB
File Format / SizePDF / 690 Kb
AD8251* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. REFERENCE MATERIALS. Technical Articles
AD8251* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS REFERENCE MATERIALS Technical Articles
View a parametric search of comparable parts.
Technical Articles
• Auto-Zero Amplifiers
EVALUATION KITS
• High-performance Adder Uses Instrumentation Amplifiers • AD8251 Evaluation Board
DESIGN RESOURCES DOCUMENTATION
• AD8251 Material Declaration
Application Notes
• PCN-PDN Information • AN-1401: Instrumentation Amplifier Common-Mode • Quality And Reliability Range: The Diamond Plot • Symbols and Footprints
Data Sheet
• AD8251: 10 MHz, 20 V/μs, G = 1, 2, 4, 8 iCMOS
DISCUSSIONS
Programmable Gain Instrumentation Amplifier Data Sheet View all AD8251 EngineerZone Discussions.
Technical Books
• A Designer's Guide to Instrumentation Amplifiers, 3rd
SAMPLE AND BUY
Edition, 2006 Visit the product page to see pricing options.
User Guides
• UG-925: Evaluating the AD8251 10 MHz, 20 V/μs, G = 1, 2,
TECHNICAL SUPPORT
4, 8 iiCMOS Programmable Gain Instrumentation Amplifier Submit a technical question or find your regional support number.
TOOLS AND SIMULATIONS DOCUMENT FEEDBACK
• AD8251 SPICE Macro Model Submit feedback for this data sheet.
REFERENCE DESIGNS
• CN0345 • CN0385
This page is dynamically generated by Analog Devices, Inc., and inserted into this data sheet. A dynamic change to the content on this page will not trigger a change to either the revision number or the content of the product data sheet. This dynamic page may be frequently modified.
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING DIAGRAM ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION GAIN SELECTION Transparent Gain Mode Latched Gain Mode Timing for Latched Gain Mode POWER SUPPLY REGULATION AND BYPASSING INPUT BIAS CURRENT RETURN PATH INPUT PROTECTION REFERENCE TERMINAL COMMON-MODE INPUT VOLTAGE RANGE LAYOUT Grounding Coupling Noise Common-Mode Rejection RF INTERFERENCE DRIVING AN ADC APPLICATIONS DIFFERENTIAL OUTPUT SETTING GAINS WITH A MICROCONTROLLER DATA ACQUISITION OUTLINE DIMENSIONS ORDERING GUIDE
