Datasheet AD8231 (Analog Devices) - 8
DescriptionZero Drift, Digitally Programmable Instrumentation Amplifier
Pages / Page17 / 8 — DLA LAND AND MARITIME. COLUMBUS, OHIO. 16236. V62/12646
File Format / SizePDF / 218 Kb
DLA LAND AND MARITIME COLUMBUS, OHIO 16236 V62/12646
TABLE I. Electrical performance characteristics – Continued. 1/ Test Symbol Conditions Temperature, Device Limits Unit V type S = 5 V, VREF = 2.5 V, TA G = 1, R L = 10 kΩ, Min Max unless otherwise specified Operational amplifier – continued. Input characteristics – continued. Input offset current IIO +25°C 01 100 pA -55°C to +125°C 0.5 nA Input voltage range VINR +25°C 01 0.05 4.95 V Open loop gain AOL +25°C 01 100 V/mV Common mode CMRR +25°C 01 100 dB rejection ratio Power supply PSRR +25°C 01 100 dB rejection ratio Voltage noise density +25°C 01 20 typical nV/ Hz Voltage noise f = 0.1 Hz to 10 Hz +25°C 01 0.4 typical µVp-p Dynamic performance. Gain bandwidth GBWP +25°C 01 1 typical MHz product Slew rate SR +25°C 01 0.5 typical V/µs Output characteristics. Output voltage high VOH RL = 100 kΩ to ground +25°C 01 4.9 V RL = 10 kΩ to ground 4.8 Output voltage low VOL RL = 100 kΩ to 5 V +25°C 01 100 mV RL = 10 kΩ to 5 V 200 Short circuit current ISC +25°C 01 70 typical mA Both amplifiers. Power supply. Quiescent current IQ +25°C 01 5 mA Quiescent current +25°C 01 1 µA (shutdown) See footnotes at end of table.
SIZE CODE IDENT NO. DWG NO.
COLUMBUS, OHIO A 16236 V62/12646
REV PAGE 8 Document Outline DESCRIPTION REV REV PMIC N/A DLA LAND AND MARITIME TITLE SIZE A V62/12646 REV
