Datasheet AMP04 (Analog Devices) - 5
DescriptionPrecision Single Supply Instrumentation Amplifier
Pages / Page18 / 5 — AMP04. AMP04E. AMP04F. Parameter. Symbol. Conditions. Min. Typ. Max. …
RevisionC
File Format / SizePDF / 557 Kb
AMP04. AMP04E. AMP04F. Parameter. Symbol. Conditions. Min. Typ. Max. Unit. WAFER TEST LIMITS (VS = 5 V, VCM = 2.5 V, TA = 25
AMP04 AMP04E AMP04F Parameter Symbol Conditions Min Typ Max Unit WAFER TEST LIMITS (VS = 5 V, VCM = 2.5 V, TA = 25
AMP04 AMP04E AMP04F Parameter Symbol Conditions Min Typ Max Min Typ Max Unit
GAIN (G = 100 K/RGAIN) Gain Equation Accuracy G = 1 to 100 0.2 0.5 0.75 % G = 1000 0.4 0.75 % G = 1 to 100 –40°C ≤ TA ≤ +85°C 0.8 1.0 % Gain Range G 1 1000 1 1000 V/V Nonlinearity G = 1, RL = 5 kΩ 0.005 0.005 % G = 10, RL = 5 kΩ 0.015 0.015 % G = 100, RL = 5 kΩ 0.025 0.025 % Gain Temperature Coefficient ∆G/∆T 30 50 ppm/°C OUTPUT Output Voltage Swing High VOH RL = 2 kΩ 13 13.4 13 V RL = 2 kΩ –40°C ≤ TA ≤ +85°C 12.5 12.5 V Output Voltage Swing Low VOL RL = 2 kΩ –40°C ≤ TA ≤ +85°C –14.5 –14.5 V Output Current Limit Sink 30 30 mA Source 15 15 mA NOISE Noise Voltage Density, RTI eN f = 1 kHz, G = 1 270 270 nV/√Hz f = 1 kHz, G = 10 45 45 nV/√Hz f = 100 Hz, G = 100 30 30 nV/√Hz f = 100 Hz, G = 1000 25 25 nV/√Hz Noise Current Density, RTI iN f = 100 Hz, G = 100 4 4 pA/√Hz Input Noise Voltage eN p-p 0.1 Hz to 10 Hz, G = 1 5 5 µV p-p 0.1 Hz to 10 Hz, G = 10 1 1 µV p-p 0.1 Hz to 10 Hz, G = 100 0.5 0.5 µV p-p DYNAMIC RESPONSE Small Signal Bandwidth BW G = 1, –3 dB 700 700 kHz POWER SUPPLY Supply Current ISY 750 900 900 µA –40°C ≤ TA ≤ +85°C 1100 1100 µA Specifications subject to change without notice.
WAFER TEST LIMITS (VS = 5 V, VCM = 2.5 V, TA = 25 C unless otherwise noted) Parameter Symbol Conditions Limit Unit
OFFSET VOLTAGE Input Offset Voltage VIOS 300 µV max Output Offset Voltage VOOS 3 mV max INPUT CURRENT Input Bias Current IB 40 nA max Input Offset Current IOS 10 nA max INPUT Common-Mode Rejection CMR 0 V ≤ VCM ≤ 3.0 V G = 1 55 dB min G = 10 75 dB min G = 100 80 dB min G = 1000 80 dB min Common-Mode Rejection CMR VS = ± 15 V, –12 V ≤ VCM ≤ +12 V G = 1 55 dB min G = 10 75 dB min G = 100 80 dB min –4– REV. C
