Datasheet AD526 (Analog Devices) - 4
Description | Software Programmable Gain Amplifier |
Pages / Page | 15 / 4 — AD526. AD526J. AD526A. AD526B/S. AD526C. Model. Min. Typ. Max. Units. … |
Revision | D |
File Format / Size | PDF / 505 Kb |
AD526. AD526J. AD526A. AD526B/S. AD526C. Model. Min. Typ. Max. Units. 4.5. 16.5. boldface
AD526 AD526J AD526A AD526B/S AD526C Model Min Typ Max Min Typ Max Min Typ Max Min Typ Max Units
NOISE, ALL GAINS Voltage Noise, RTI 0.1 Hz to 10 Hz 3 3 3 3 µV p-p Voltage Noise Density, RTI f = 10 Hz 70 70 70 70 nV√Hz f = 100 Hz 60 60 60 60 nV√Hz f = 1 kHz 30 30 30 30 nV√Hz f = 10 kHz 25 25 25 35 nV√Hz DYNAMIC RESPONSE –3 dB Bandwidth (Small Signal) G = 1 4.0 4.0 4.0 4.0 MHz G = 2 2.0 2.0 2.0 2.0 MHz G = 4 1.5 1.5 1.5 1.5 MHz G = 8 0.65 0.65 0.65 0.65 MHz G = 16 0.35 0.35 0.35 0.35 MHz Signal Settling Time to 0.01% (∆VOUT = ± 10 V) G = 1 2.1 4 2.1 4 2.1 4 2.1 4 µs G = 2 2.5 5 2.5 5 2.5 5 2.5 5 µs G = 4 2.7 5 2.7 5 2.7 5 2.7 5 µs G = 8 3.6 7 3.6 7 3.6 7 3.6 7 µs G = 16 4.1 7 4.1 7 4.1 7 4.1 7 µs Full Power Bandwidth G = 1, 2, 4 0.10 0.10 0.10 0.10 MHz G = 8, 16 0.35 0.35 0.35 0.35 MHz Slew Rate G = 1, 2, 4
4
6
4
6
4
6
4
6 V/µs G = 8, 16
18
24
18
24
18
24
18
24 V/µs DIGITAL INPUTS (TMIN to TMAX) Input Current (VH = 5 V) 60 100 140 60 100 140 60 100 140 60 100 140 µA Logic “1” 2 6 2 6 2 6 2 6 V Logic “0” 0 0.8 0 0.8 0 0.8 0 0.8 V TIMING1 (VL = 0.2 V, VH = 3.7 V) A0, A1, A2 TC 50 50 50 50 ns TS 30 30 30 30 ns TH 30 30 30 30 ns B TC 50 50 50 50 ns TS 40 40 40 40 ns TH 10 10 10 30 ns TEMPERATURE RANGE Specified Performance 0 +70 –40 +85 –40/–55 +85/+125 –40 +85 °C Storage –65 +125 –65 +150 –65 +150 –65 +150 °C POWER SUPPLY Operating Range ⴞ
4.5
ⴞ
16.5
ⴞ
4.5
ⴞ
16.5
ⴞ
4.5
ⴞ
16.5
ⴞ
4.5
ⴞ
16.5
V Positive Supply Current 10
14
10
14
10
14
10
14
mA Negative Supply Current 10
13
10
13
10
13
10
13
mA PACKAGE OPTIONS Plastic (N-16) AD526JN Ceramic DIP (D-16) AD526AD AD526BD AD526SD AD526CD AD526SD/883B NOTES 1Refer to Figure 25 for definitions. FSR = Full Scale Range = 20 V. RTI = Referred to Input. Specifications subject to change without notice. Specifications shown in
boldface
are tested on all production units at final electrical test. All min and max specifications are guaranteed, although only those shown in boldface are tested on all production units. –3– REV. D
