Datasheet ADUM3190 (Analog Devices) - 5
Description2.5kV rms Isolated Error Amplifier
Pages / Page19 / 5 — ADuM3190. Data Sheet. Parameter. Test Conditions/Comments. Min. Typ. Max. …
File Format / SizePDF / 596 Kb
ADuM3190. Data Sheet. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
ADuM3190 Data Sheet Parameter Test Conditions/Comments Min Typ Max Unit
link to page 10 link to page 10
POWER SUPPLY Operating Range, Side 1 VDD1 3.0 20 V Operating Range, Side 2 VDD2 3.0 20 V Power Supply Rejection DC, VDD1 = VDD2 = 3 V to 20 V 60 dB Supply Current IDD1 See Figure 4 1.4 2.0 mA IDD2 See Figure 5 2.9 5.0 mA 1 Output gain is defined as the slope of the best-fit line of the output voltage vs. the input voltage over the specified input range, with the offset error adjusted out. 2 Output linearity is defined as the peak-to-peak output deviation from the best-fit line of the output gain, expressed as a percentage of the full-scale output voltage. Rev. A | Page 4 of 18 Document Outline Features Applications General Description Functional Block Diagram Table of Contents Revision History Specifications Package Characteristics Regulatory Information Insulation and Safety Related Specifications Recommended Operating Conditions DIN V VDE V 0884-10 (VDE V 0884-10) Insulation Characteristics Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Test Circuits Applications Information Theory of Operation Accuracy Circuit Operation Isolated Amplifier Circuit Operation Application Block Diagram Setting the Output Voltage DOSA Module Application DC Correctness and Magnetic Field Immunity Insulation Lifetime Packaging and Ordering Information Outline Dimensions Ordering Guide Automotive Products
