Datasheet ADL6010 (Analog Devices) - 7
DescriptionFast Responding, 45 dB Range, 0.5 GHz TO 43.5 GHz Envelope Detector
Pages / Page22 / 7 — Data Sheet. ADL6010. ABSOLUTE MAXIMUM RATINGS Table 2. Parameter. Rating. …
RevisionC
Data Sheet. ADL6010. ABSOLUTE MAXIMUM RATINGS Table 2. Parameter. Rating. ESD CAUTION
Data Sheet ADL6010 ABSOLUTE MAXIMUM RATINGS Table 2 Parameter Rating ESD CAUTION
Data Sheet ADL6010 ABSOLUTE MAXIMUM RATINGS Table 2.
Stresses at or above those listed under Absolute Maximum
Parameter Rating
Ratings may cause permanent damage to the product. This is a stress rating only; functional operation of the product at these Supply Voltage, VPOS 5.5 V or any other conditions above those indicated in the operational Input RF Power1 20 dBm section of this specification is not implied. Operation beyond Equivalent Voltage, Sine Wave Input 3.16 V the maximum operating conditions for extended periods may Internal Power Dissipation 20 mW affect product reliability. θ 2 JC 16.4°C/W θ 2 JA 82.9°C/W Ψ 2 JT 0.6°C/W
ESD CAUTION
Ψ 2 JB 49.3°C/W Maximum Junction Temperature 150°C Operating Temperature Range ADL6010ACPZN-R7 −40°C < TA < +85°C ADL6010SCPZN-R7 −55°C < TA < +125°C Storage Temperature Range −65°C to +150°C Lead Temperature (Soldering 60 sec) 300°C 1 Driven from a 50 Ω source. 2 No airflow when the exposed pad soldered to a 4-layer JEDEC board. Rev. B | Page 7 of 22 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS MEASUREMENT SETUPS THEORY OF OPERATION BASIC CONNECTIONS PCB LAYOUT RECOMMENDATIONS SYSTEM CALIBRATION AND ERROR CALCULATION EFFECT OF A CAPACITAVE LOAD ON RISE TIME AND FALL TIME EVALUATION BOARD EVALUATION BOARD ASSEMBLY DRAWINGS OUTLINE DIMENSIONS ORDERING GUIDE
