Datasheet HMC662LP3E (Analog Devices) - 5
Description54 dB Logarithmic Detector, 8 - 30 GHz
Pages / Page9 / 5 — HMC662LP3E. 54 dB, LOGARITHMIC. DETECTOR, 8 - 30 GHz. Fall Time @ 10 GHz …
File Format / SizePDF / 506 Kb
HMC662LP3E. 54 dB, LOGARITHMIC. DETECTOR, 8 - 30 GHz. Fall Time @ 10 GHz @ 0 dBm. Rise Time @ 10 GHz @ 0 dBm. Input Return Loss
HMC662LP3E 54 dB, LOGARITHMIC DETECTOR, 8 - 30 GHz Fall Time @ 10 GHz @ 0 dBm Rise Time @ 10 GHz @ 0 dBm Input Return Loss
HMC662LP3E
v05.0914
1.8 1.8 1.6 1.6 T M (V) 1.4 (V) 1.4 S OUT OUT - 1.2 1.2 LOG LOG RS 1 1 O T 0.8 0.8 0 20 40 60 80 100 0 20 40 60 80 100 C TIME (ns) TIME (ns) TE E D
Input Return Loss LOG OUT vs. Frequency
R 0 2 10 GHz -5 14 GHz WE 1.7 18 GHz 24 GHz (dB) -10 28 GHz O 30 GHz (V) P LOSS -15 1.4 OUT +25C LOG -20 +85C RETURN -40C 1.1 -25 -30 0.8 0 10 20 30 40 -60 -50 -40 -30 -20 -10 0 10 FREQUENCY (GHz) INPUT POWER (dBm) Unless otherwise noted: Vcc1, Vcc2 = +3.3V, TA = +25 °C I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 • Fax: 978-250-3373 • O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Ph e o r O ne n : 7 -l 81 i-n 3 e a 29-4t w 70 ww 0 • O .h rd iettit r o e nli.c n om license is granted by implication or otherwise under any patent or patent rights of Analog Devices. e at www.analog.com
4
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners.ne: 978-250-33A4 p 3 p o lic ra a tiopp n S su@ p h po irtttit : Pe. hocnom e: 1-800-ANALOG-D
