Datasheet HMC662LP3E (Analog Devices) - 6
Description54 dB Logarithmic Detector, 8 - 30 GHz
Pages / Page9 / 6 — HMC662LP3E. 54 dB, LOGARITHMIC. DETECTOR, 8 - 30 GHz. Absolute Maximum …
File Format / SizePDF / 506 Kb
HMC662LP3E. 54 dB, LOGARITHMIC. DETECTOR, 8 - 30 GHz. Absolute Maximum Ratings. Outline Drawing. Package Information
HMC662LP3E 54 dB, LOGARITHMIC DETECTOR, 8 - 30 GHz Absolute Maximum Ratings Outline Drawing Package Information
HMC662LP3E
v05.0914
EN +3.6V T Vcc1. Vcc2 +3.6V ELECTROSTATIC SENSITIVE DEVICE M RF Input Power +12 dBm OBSERVE HANDLING PRECAUTIONS Junction Temperature 125 °C S - Continuous Pdiss (T = 85°C) 0.51W (Derate 12.63 mW/°C above 85°C) Thermal Resistance (R ) th RS 15.29 °C/W (junction to ground paddle) O Storage Temperature -65 to +150 °C T Operating Temperature -40 to +85 °C C ESD Sensitivity (HBM) Class 0 TE E D R
Outline Drawing
WE O P NOTES: 1. LEADFRAME MATERIAL: COPPER ALLOY 2. DIMENSIONS ARE IN INCHES [MILLIMETERS]. 3. LEAD SPACING TOLERANCE IS NON-CUMULATIVE 4. PAD BURR LENGTH SHALL BE 0.15mm MAXIMUM. PAD BURR HEIGHT SHALL BE 0.05mm MAXIMUM. 5. PACKAGE WARP SHALL NOT EXCEED 0.05mm. 6. ALL GROUND LEADS AND GROUND PADDLE MUST BE SOLDERED TO PCB RF GROUND. 7. REFER TO HMC APPLICATION NOTE FOR SUGGESTED PCB LAND PATTERN.
Package Information
Part Number Package Body Material Lead Finish MSL Rating Package Marking [1] HMC662LP3E RoHS-compliant Low Stress Injection Molded Plastic 100% matte Sn MSL1 [2] 662 XXX [1] 4-Digit lot number XXXX [2] Max peak reflow temperature of 260 °C I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 • Fax: 978-250-3373 • O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Ph e o r O ne n : 7 -l 81 i-n 3 e a 29-4t w 70 ww 0 • O .h rd iettit r o e nli.c n om
5
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. e at www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners.ne: 978-250-33A4 p 3 p o lic ra a tiopp n S su@ p h po irtttit : Pe. hocnom e: 1-800-ANALOG-D
