Datasheet HMC913 (Analog Devices) - 6
DescriptionSUCCESSIVE DETECTION LOG VIDEO AMPLIFER (SDLVA), 0.6 - 20 GHz
Pages / Page9 / 6 — HMC913. SUCCESSIVE DETECTION LOG VIDEO. AMPLIFER (SDLVA), 0.6 - 20 GHz. …
File Format / SizePDF / 625 Kb
HMC913. SUCCESSIVE DETECTION LOG VIDEO. AMPLIFER (SDLVA), 0.6 - 20 GHz. Pad Descriptions
HMC913 SUCCESSIVE DETECTION LOG VIDEO AMPLIFER (SDLVA), 0.6 - 20 GHz Pad Descriptions
HMC913
v04.0913
Pad Number Function Description Interface Schematic IP H C Bias Supply. Connect Supply Voltage to these pins - with appropriate filtering. 1 - 5 VCC1 To ensure proper start-up supply As rise time should be faster than 100usec LV SD Bias Supply. Connect supply voltage to these pins with appropriate filtering. 6 VCC2 To ensure proper start-up supply rise time should be faster than 100usec Enable pin connected to VCC1 or VCC2 for normal 7 EN operation. Total supply current reduced to less than 3mA when EN is set to 0V. 8, 11 - 18, 21, 22 These pins and the die bottom must be connected to a high GND Die Bottom quality RF/DC ground. Video out and feedback. These pins should be shorted to VIDEO OUT, 9, 10 each other (see application circuit). Video out load should VIDEO FB be at least 1K Ohm or higher. Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
6
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 p o lica rti a o p n S p u s p @ po h rt itt : P ite ho . n c e om : 1-800-ANALOG-D
