Datasheet HMC813LC4B (Analog Devices) - 7
DescriptionSUCCESSIVE DETECTION LOG VIDEO AMPLIFIER (SDLVA) WITH LIMITED RF OUTPUT, 1 - 20 GHz
Pages / Page10 / 7 — HMC813LC4B. SUCCESSIVE DETECTION LOG VIDEO AMPLIFIER (SDLVA). WITH …
File Format / SizePDF / 902 Kb
HMC813LC4B. SUCCESSIVE DETECTION LOG VIDEO AMPLIFIER (SDLVA). WITH LIMITED RF OUTPUT, 1 - 20 GHz. Pin Descriptions
HMC813LC4B SUCCESSIVE DETECTION LOG VIDEO AMPLIFIER (SDLVA) WITH LIMITED RF OUTPUT, 1 - 20 GHz Pin Descriptions
HMC813LC4B
v03.0614
Pin Number Function Description Interface Schematic T The pins are not connected internally; however, all data M 1-3, 6-9, 11-13, N/C shown herein was measured with these pins connected to 19, 24 S RF/DC ground externally. - RS O T RF Input pins. Connect RF to RFINP, and AC couple C 4, 5 RFINP, RFINN RFINN to ground via 50 Ohm for single ended operation. E T E D R E W O P 10 VIDEO OUT Video out load should be at least 1K Ohm or higher. RFOUTN, RF Output pins. Connect RF to RFOUTP, and AC couple 14, 15 RFOUTP RFOUTN to ground via 50 Ohm for single ended operation These pins and the exposed package bottom must be 16, 18 GND connected to a high quality RF/DC ground. I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m
7
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte ho.c n o e m : 1-800-ANALOG-D
