Datasheet HMC713MS8, 713MS8E (Analog Devices) - 5
Description54 dB, Logarithmic Detector/Controller SMT, 45 - 2700 MHz
Pages / Page12 / 5 — HMC713MS8 / 713MS8E. 54 DB, LOGARITHMIC. DETECTOR / CONTROLLER, 45 - 2700 …
HMC713MS8 / 713MS8E. 54 DB, LOGARITHMIC. DETECTOR / CONTROLLER, 45 - 2700 MHz. Output Voltage & Error
HMC713MS8 / 713MS8E 54 DB, LOGARITHMIC DETECTOR / CONTROLLER, 45 - 2700 MHz Output Voltage & Error
HMC713MS8 / 713MS8E
v06.0412
54 DB, LOGARITHMIC DETECTOR / CONTROLLER, 45 - 2700 MHz Output Voltage & Error Output Voltage & Error vs. Input Power, Fin = 45 MHz vs. Input Power, Fin = 100 MHz
2.4 6 2.4 6 t OUT Err +25C OUT Err +25C OUT Err +85C 2 4 OUT Err -40C 2 OUT Err +85C 4 M OUT Err -40C OUT N Err +25C OUT N Err +25C OUT N Err +85C OUT N Err +85C 1.6 OUT N Err -40C 2 OUT N Err -40C 2 s 1.6 E E R R - R R O O 1.2 0 R 1.2 0 R ( d d B B ) rs OUT, OUTN (V) 0.8 -2 OUT, OUTN (V) 0.8 -2 o OUT OUT 0.4 -4 0.4 OUT N -4 t OUT N c 0 -6 0 -6 e -60 -50 -40 -30 -20 -10 0 10 -60 -50 -40 -30 -20 -10 0 10 t INPUT POWER (dBm) INPUT POWER (dBm) e D
r
vs. Input Power, Fin = 900 MHz vs. Input Power, Fin = 1900 MHz
e 2.4 6 2.4 6 w OUT Err +25C OUT Err +25C OUT Err +85C o 2 4 2 OUT Err +85C 4 OUT Err -40C OUT Err -40C OUT N Err +25C P OUT N Err +25C OUT N Err +85C 1.6 OUT N Err -40C 2 1.6 OUT N Err +85C 2 E OUT N Err -40C E R R R R O O 1.2 0 R 1.2 0 R ( d d B B -2 ) OUT, OUTN (V) 0.8 OUT, OUTN (V) 0.8 -2 OUT OUT 0.4 OUT N -4 0.4 OUT N -4 0 -6 0 -6 -60 -50 -40 -30 -20 -10 0 10 -60 -50 -40 -30 -20 -10 0 10 Input Power (dBm) INPUT POWER (dBm)
Output Voltage & Error Output Voltage & Error vs. Input Power, Fin = 2200 MHz vs. Input Power, Fin = 2700 MHz
2.4 6 2.4 6 OUT Err +25C OUT Err +25C 2 OUT Err +85C 4 2 OUT Err +85C 4 OUT Err -40C OUT Err -40C OUT N Err +25C OUT N Err +25C 1.6 OUT N Err +85C 2 OUT N Err -40C E 1.6 OUT N Err +85C 2 OUT N Err -40C R E R R O R 1.2 0 O R 1.2 0 ( R d ( B d ) B OUT, OUTN (V) 0.8 -2 OUT, OUTN (V) 0.8 -2 ) OUT OUT 0.4 OUT N -4 0.4 OUT N -4 0 -6 0 -6 -60 -50 -40 -30 -20 -10 0 10 -60 -50 -40 -30 -20 -10 0 10 INPUT POWER (dBm) NPUT POWER (dBm) Unless otherwise noted: Vcc= +3V, TA = +25 °C I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m
3
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte. ho c n o e m : 1-800-ANALOG-D
