Datasheet HMC713MS8, 713MS8E (Analog Devices) - 6
Description54 dB, Logarithmic Detector/Controller SMT, 45 - 2700 MHz
Pages / Page12 / 6 — HMC713MS8 / 713MS8E. 54 DB, LOGARITHMIC. DETECTOR / CONTROLLER, 45 - 2700 …
HMC713MS8 / 713MS8E. 54 DB, LOGARITHMIC. DETECTOR / CONTROLLER, 45 - 2700 MHz. OUT Slope vs. Frequency
HMC713MS8 / 713MS8E 54 DB, LOGARITHMIC DETECTOR / CONTROLLER, 45 - 2700 MHz OUT Slope vs Frequency
HMC713MS8 / 713MS8E
v06.0412
54 DB, LOGARITHMIC DETECTOR / CONTROLLER, 45 - 2700 MHz OUT Slope vs. Frequency OUT Slope vs. Supply Voltage
20 20 0.045GHz 19 +25C slope +85C slope 0.1GHz 19 t -40C slope 0.9GHz 1.9GHz 18 M 2.2GHz 18 2.7GHz s 17 - 17 SLOPE (mV/dB) 16 SLOPE (mV/dB) rs 16 15 o t 14 15 0 0.3 0.6 0.9 1.2 1.5 1.8 2.1 2.4 2.7 2.7 3.1 3.5 3.9 4.3 4.7 5.1 5.5 c FREQUENCY (GHz) VOLTAGE SUPPLY (V) e t e D
OUT Intercept vs. Frequency OUT Intercept vs. Supply Voltage
r -50 -50 e -60 -60 w o -70 -70 P -80 -80 0.045GHz 0.1GHz INTERCEPT (dBm) INTERCEPT (dBm) 0.9GHz +25C intercept 1.9GHz -90 +85C intercept -90 2.2GHz -40C intercept 2.7GHz -100 -100 0 0.3 0.6 0.9 1.2 1.5 1.8 2.1 2.4 2.7 2.7 3.1 3.5 3.9 4.3 4.7 5.1 5.5 FREQUENCY (GHz) VOLTAGE SUPPLY (V)
OUT vs. Frequency & Input Power OUT Voltage & Error vs. Frequency
1.4 1.8 6 0dBm 1.2 1.5 4 -10dBm 1 -20dBm 1.2 2 E R 0.8 Error R -30dBm O 0.9 0 R ( OUT (V) 0.6 -40dBm OUT (V) dB 0.6 OUT -2 ) 0.4 -50dBm 0.045GHz 0.1GHz 0.2 0.3 0.9GHz -4 1.9GHz 2.2GHz -60dBm 2.7GHz 0 0 -6 0 0.3 0.6 0.9 1.2 1.5 1.8 2.1 2.4 2.7 -60 -50 -40 -30 -20 -10 0 10 FREQUENCY (GHz) INPUT POWER (dBm) Unless otherwise noted: Vcc= +3V, TA = +25 °C I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com
4
Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte. ho c n o e m : 1-800-ANALOG-D
