Datasheet HMC713LP3E (Analog Devices) - 2
Description54 dB, LOGARITHMIC DETECTOR / CONTROLLER, 50 - 8000 MHz
Pages / Page12 / 2 — HMC713LP3E. 54 dB, LOGARITHMIC. DETECTOR / CONTROLLER, 50 - 8000 MHz. …
File Format / SizePDF / 918 Kb
HMC713LP3E. 54 dB, LOGARITHMIC. DETECTOR / CONTROLLER, 50 - 8000 MHz. Electrical Specifications, (continued)
HMC713LP3E 54 dB, LOGARITHMIC DETECTOR / CONTROLLER, 50 - 8000 MHz Electrical Specifications, (continued)
HMC713LP3E
v01.1009
Parameter conditions Min. typ. Max. Units
Power Down (EN) Input
Voltage range for Normal Mode 0.8 x Vcc Vcc/2 V Voltage range for Powerdown Mode Vcc/2 0.2 x Vcc V
Power Supply (Vcc)
operating Voltage range 2.7 - 5.5 V supply current in Normal Mode eN Input at Vcc 17 mA supply current in Power Down Mode eN Input at GND 0.4 mA
OUTP Output
rise time cLPF= 0, No Power to -10 dBm, 10% - 90% 24 ns Fall time cLPF= 0, -10 dBm to No Power, 90% - 10% 36 ns 11 50mV reduction in output voltage swing output Video Bw (3 dB referred to the input) [1] 16 MHz Voltage range closed Loop (eval Board setup) 0.2 - 1.2 V t 0.1 to Voltage range open Loop V M (Vcc -0.1) s current Drive source / sink 4.2 / 0.48 mA
OUTN Output
s - current Drive source / sink 4.0 / 0.43 mA output Voltage range 0.2 - 2.1 V r
RF Input
o F= 50 MHz to 8 GHz t Input return Loss (s11) 10 dB Z0= 50Ω, see plot c
VSET Input
e Input Impedance 1 MΩ t Input Voltage range eval Board 0.2 - 1.2 V e Low Frequency Gain Vset to oUtP 64 dB D open Loop corner Frequency 11 kHz r e w o P [1] two tone test: Frequency = 900 MHz, tone 1 Power = -20 dBm, tone 2 Power = -28 dBm Inf F or o m rat ip o r n ifc ur e n ,is hd e e d lbiv y e Anry alo a g n D d evi cto es ips la beclie ev eo d rtd o e b r e sa: ccH ur iattte itaen M d reliic a r bl o e w . H a o v weev eC r, o n r o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other poration, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 rights of third parties that may result from its use. Specifications subject to change without notice. No Or P d hoe n r e O : 7 n- 81-li 3 n 2 e 9- a 4 t 7 0 www 0 • O . rdh e itt r o it n e li . n co e a m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com
11 - 2
Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 p p liocra t ia o pp n S s u @ p h por ittti : Pte. ho c n o e m : 1-800-ANALOG-D
