Datasheet HMC713LP3E (Analog Devices) - 7
Description54 dB, LOGARITHMIC DETECTOR / CONTROLLER, 50 - 8000 MHz
Pages / Page12 / 7 — HMC713LP3E. 54 dB, LOGARITHMIC. DETECTOR / CONTROLLER, 50 - 8000 MHz. …
File Format / SizePDF / 918 Kb
HMC713LP3E. 54 dB, LOGARITHMIC. DETECTOR / CONTROLLER, 50 - 8000 MHz. Absolute Maximum Ratings. Outline Drawing
HMC713LP3E 54 dB, LOGARITHMIC DETECTOR / CONTROLLER, 50 - 8000 MHz Absolute Maximum Ratings Outline Drawing
HMC713LP3E
v01.1009
Vcc 0 to +5.6V eN Input Voltage 0 to +5.6V eLectrostAtIc seNsItIVe DeVIce oBserVe HANDLING PrecAUtIoNs Vset Input Voltage 0 to +5.6V oUtP output current 5 mA oUtN output current 5 mA rF Input Power 12 dBm Junction temperature 125 °c continuous Pdiss (t = 85°c) 11 0.22 watts (Derate 5.43 mw/°c above 85°c) thermal resistance (r ) th 184 °c/w (junction to lead) storage temperature -65 to +150 °c t operating temperature -40 to +85 °c M esD sensitivity (HBM) class 1c s s -
Outline Drawing
r o t c e t e r D e w o P Notes: 1. LeADFrAMe MAterIAL: coPPer ALLoY 2. DIMeNsIoNs Are IN INcHes [MILLIMeters]. 3. LeAD sPAcING toLerANce Is NoN-cUMULAtIVe 4. PAD BUrr LeNGtH sHALL Be 0.15mm MAXIMUM. PAD BUrr HeIGHt sHALL Be 0.05mm MAXIMUM. 5. PAcKAGe wArP sHALL Not eXceeD 0.05mm. 6. ALL GroUND LeADs AND GroUND PADDLe MUst Be soLDereD to PcB rF GroUND. 7. reFer to HMc APPLIcAtIoN Note For sUGGesteD PcB LAND PAtterN.
Package Information
Part Number Package Body Material Lead Finish MsL rating Package Marking [1] HMc713LP3e roHs-compliant Low stress Injection Molded Plastic 100% matte sn MsL1 [2] 713 XXXX [1] 4-Digit lot number XXXX [2] Max peak reflow temperature of 260 °c Inf F or o m rat ip o r n ifc ur e n ,is hd e e d lbiv y e Anry alo a g n D d evi cto es ips la beclie ev eo d rtd o e b r e sa: ccH ur iattte itaen M d reliic a r bl o e w . H a o v weev eC r, o n r o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other poration, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 rights of third parties that may result from its use. Specifications subject to change without notice. No Or P d hoe n r e O : 7 n- 81-li 3 n 2 e 9- a 4 t 7 0 www 0 • O . rdh e itt r o it n e li . n co e a m
11 - 7
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 p p liocra t ia o pp n S s u @ p h por ittti : Pte. ho c n o e m : 1-800-ANALOG-D
