Datasheet AD8318 (Analog Devices) - 6
Description1 MHz TO 8 GHz, 70 dB Logarithmic Detector/Controller
Pages / Page17 / 6 — DLA LAND AND MARITIME. COLUMBUS, OHIO. 16236. V62/12665
File Format / SizePDF / 179 Kb
DLA LAND AND MARITIME COLUMBUS, OHIO 16236 V62/12665
TABLE I. Electrical performance characteristics – Continued. 1/ Test Symbol Conditions 2/ Temperature, Device Limits Unit T type A Min Max Measurement mode. VOUT pin shorted to VSET pin, sinusoidal input signal. f = 1.9 GHz, RTADJ = 500 Ω. Input impedance 3/ +25°C 01 523||0.68 typical Ω||pF ±3 dB dynamic range +25°C 01 65 typical dB -55°C to +105°C 63 typical ±1 dB dynamic range +25°C 01 57 typical dB Maximum input level ±1 dB error -55°C to +105°C 01 -2 typical dBm Minimum input level ±1 dB error -55°C to +105°C 01 -59 typical dBm Slope -55°C to +105°C 01 -27 -22 mV/dB Intercept -55°C to +105°C 01 17 24 dBm Output voltage - PIN = -10 dBm -55°C to +105°C 01 0.63 0.83 V high power in Output voltage - PIN = -35 dBm -55°C to +105°C 01 1.2 1.5 V low power in Temperature sensitivity PIN = -10 dBm +25°C to +105°C 01 0.0056 typical dB/°C -55°C to +25°C 0.0004 typical See footnotes at end of table.
SIZE CODE IDENT NO. DWG NO.
COLUMBUS, OHIO A 16236 V62/12665
REV PAGE 6 Document Outline DESCRIPTION REV REV PMIC N/A DLA LAND AND MARITIME TITLE SIZE A V62/12665 REV
