Datasheet AD8318 (Analog Devices) - 10
Description1 MHz TO 8 GHz, 70 dB Logarithmic Detector/Controller
Pages / Page17 / 10 — DLA LAND AND MARITIME. COLUMBUS, OHIO. 16236. V62/12665
File Format / SizePDF / 179 Kb
DLA LAND AND MARITIME COLUMBUS, OHIO 16236 V62/12665
TABLE I. Electrical performance characteristics – Continued. 1/ Test Symbol Conditions 2/ Temperature, Device Limits Unit T type A Min Max Measurement mode. VOUT pin shorted to VSET pin, sinusoidal input signal. f = 8.0 GHz, RTADJ = 500 Ω. ±3 dB dynamic range +25°C 01 60 typical dB -55°C to +105°C 58 typical Maximum input level ±1 dB error -55°C to +105°C 01 3 typical dBm Minimum input level ±1 dB error -55°C to +105°C 01 -55 typical dBm Slope -55°C to +105°C 01 -23 typical mV/dB Intercept -55°C to +105°C 01 37 typical dBm Output voltage - PIN = -10 dBm -55°C to +105°C 01 1.06 typical V high power in Output voltage - PIN = -40 dBm -55°C to +105°C 01 1.78 typical V low power in Temperature sensitivity PIN = -10 dBm +25°C to +105°C 01 0.032 typical dB/°C -55°C to +25°C 0.0078 typical Output interface. VOUT pin. Voltage swing V -55°C to +105°C 01 4.9 typical V SET = 0 V, PIN = -10 dBm, 4/ no load V 25 typical mV SET = 2.1 V, PIN = -10 dBm, 4/ no load Output current drive VSET = 1.5 V, PIN = -50 dBm -55°C to +105°C 01 60 typical mA Small signal bandwidth SSBW PIN = -10 dBm, from CLPF to VOUT -55°C to +105°C 01 60 typical MHz Video bandwidth or -55°C to +105°C 01 45 typical MHz envelope bandwidth Output noise P -55°C to +105°C 01 90 typical nV / IN = 2.2 GHZ, -10 dBm, f Hz NOISE = 100 kHz, CLPF = 220 pF Fall time tF PIN = off to -10 dBm, 90% to 10% -55°C to +105°C 01 10 typical ns Rise time tR PIN = -10 dBm to off, 10% to 90% -55°C to +105°C 01 12 typical ns See footnotes at end of table.
SIZE CODE IDENT NO. DWG NO.
COLUMBUS, OHIO A 16236 V62/12665
REV PAGE 10 Document Outline DESCRIPTION REV REV PMIC N/A DLA LAND AND MARITIME TITLE SIZE A V62/12665 REV
