Datasheet AD8310 (Analog Devices) - 2
DescriptionFast, Voltage-Out, DC to 440 MHz, 95 dB Logarithmic Amplifier
Pages / Page25 / 2 — AD8310* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionF
File Format / SizePDF / 436 Kb
AD8310* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. REFERENCE MATERIALS
AD8310* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS REFERENCE MATERIALS
View a parametric search of comparable parts.
Product Selection Guide
• RF Source Booklet
EVALUATION KITS Technical Articles
• AD8310 Evaluation Board • Design a Logamp RF Pulse Detector • Detecting Fast RF Bursts using Log Amps
DOCUMENTATION
• Log Amps and Directional Couplers Enable VSWR
Application Notes
Detection • AN-1040: RF Power Calibration Improves Performance of • Make Precise Base-Station Power Measurements Wireless Transmitters • Measurement and Control of RF Power, Part I • AN-691: Operation of RF Detector Products at Low • Measurement and Control of RF Power, Part II Frequency • Measurement and Control of RF Power, Part III
Data Sheet
• Measuring the RF Power in CDMA2000 and W-CDMA High • AD8310: Fast, Voltage-Out DC-440 MHz 95 dB Logarithmic Power Amplifiers (HPAs) Amplifier Data Sheet • Measuring VSWR and Gain in Wireless Systems
Product Highlight Tutorials
• Industrial Applications • Design and Operation of Automatic Gain Control Loops for Receivers in Modern Communication Systems
TOOLS AND SIMULATIONS
• ADIsimPLL™
DESIGN RESOURCES
• ADIsimRF • AD8310 Material Declaration • AD8310 SPICE Model • PCN-PDN Information • AD8310 Sub Circuit • Quality And Reliability • Symbols and Footprints
DISCUSSIONS
View all AD8310 EngineerZone Discussions.
SAMPLE AND BUY
Visit the product page to see pricing options.
TECHNICAL SUPPORT
Submit a technical question or find your regional support number.
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION PROGRESSIVE COMPRESSION SLOPE AND INTERCEPT CALIBRATION OFFSET CONTROL PRODUCT OVERVIEW ENABLE INTERFACE INPUT INTERFACE OFFSET INTERFACE OUTPUT INTERFACE USING THE AD8310 BASIC CONNECTIONS TRANSFER FUNCTION IN TERMS OF SLOPE AND INTERCEPT dBV vs. dBm INPUT MATCHING NARROW-BAND MATCHING GENERAL MATCHING PROCEDURE Step 1: Tune Out CIN Step 2: Calculate CO and LO Step 3: Split CO into Two Parts Step 4: Calculate LM SLOPE AND INTERCEPT ADJUSTMENTS INCREASING THE SLOPE TO A FIXED VALUE OUTPUT FILTERING LOWERING THE HIGH-PASS CORNER FREQUENCY OF THE OFFSET COMPENSATION LOOP APPLICATIONS INFORMATION CABLE-DRIVING DC-COUPLED INPUT EVALUATION BOARD DIE INFORMATION OUTLINE DIMENSIONS ORDERING GUIDE
