Datasheet LTC6900 (Analog Devices) - 3
DescriptionLow Power, 1kHz to 20MHz Resistor Set SOT-23 Oscillator
Pages / Page12 / 3 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
File Format / SizePDF / 164 Kb
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full operating
LTC6900
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. V+ = 2.7V to 5.5V, RL= 5k, CL = 5pF, Pin 4 = V + unless otherwise noted. All voltages are with respect to GND. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
V+ Operating Supply Range ● 2.7 5.5 V IS Power Supply Current RSET = 400k, Pin 4 = V+, RL = ∞ V+ = 5V ● 0.32 0.42 mA fOSC = 5kHz V+ = 3V ● 0.29 0.38 mA RSET = 20k, Pin 4 = 0V, RL = ∞ V+ = 5V ● 0.92 1.20 mA fOSC = 10MHz V+ = 3V ● 0.68 0.86 mA VIH High Level DIV Input Voltage ● V+ – 0.4 V VIL Low Level DIV Input Voltage ● 0.5 V IDIV DIV Input Current (Note 5) Pin 4 = V+ V+ = 5V ● 2 4 μA Pin 4 = 0V V+ = 5V ● – 4 –2 μA VOH High Level Output Voltage (Note 5) V+ = 5V IOH = – 1mA ● 4.8 4.95 V IOH = –4mA ● 4.5 4.8 V V+ = 3V IOH = – 1mA ● 2.7 2.9 V IOH = –4mA ● 2.2 2.6 V VOL Low Level Output Voltage (Note 5) V+ = 5V IOL = 1mA ● 0.05 0.15 V IOL = 4mA ● 0.2 0.4 V V+ = 3V IOL = 1mA ● 0.1 0.3 V IOL = 4mA ● 0.4 0.7 V tr OUT Rise Time V+ = 5V Pin 4 = V+ or Floating, RL = ∞ 14 ns (Note 6) Pin 4 = 0V, RL = ∞ 7 ns V+ = 3V Pin 4 = V+ or Floating, RL = ∞ 19 ns Pin 4 = 0V, RL = ∞ 11 ns tf OUT Fall Time V+ = 5V Pin 4 = V+ or Floating, RL = ∞ 13 ns (Note 6) Pin 4 = 0V, RL = ∞ 6 ns V+ = 3V Pin 4 = V+ or Floating, RL = ∞ 19 ns Pin 4 = 0V, RL = ∞ 10 ns
Note 1:
Note 5:
To conform with the Logic IC Standard convention, current out of may cause permanent damage to the device. Exposure to any Absolute a pin is arbitrarily given as a negative value. Maximum Rating condition for extended periods may affect device
Note 6:
Output rise and fall times are measured between the 10% and 90% reliability and lifetime. power supply levels. These specifi cations are based on characterization.
Note 2:
Frequencies near 100kHz and 1MHz may be generated using two
Note 7:
Guaranteed by 5V test. different values of RSET (see the Selecting the Divider Setting Resistor
Note 8:
The LTC6900C is guaranteed to meet specifi ed performance from paragraph in the Applications Information section). For these frequencies, 0°C to 70°C. The LTC6900C is designed, characterized and expected to the error is specifi ed under the following assumption: 20k < RSET ≤ 200k. meet specifi ed performance from – 40°C to 85°C but is not tested or
Note 3:
Frequency accuracy is defi ned as the deviation from the QA sampled at these temperatures. The LTC6900I is guaranteed to meet fOSC equation. specifi ed performance from –40°C to 85°C.
Note 4:
Jitter is the ratio of the peak-to-peak distribution of the period to the mean of the period. This specifi cation is based on characterization and is not 100% tested. Also, see the Peak-to-Peak Jitter vs Output Frequency curve in the Typical Performance Characteristics section. 6900fa 3
