Datasheet LTC1693 (Linear Technology) - 2
Manufacturer | Linear Technology |
Description | High Speed Single/Dual N-Channel MOSFET Drivers |
Pages / Page | 20 / 2 — ABSOLUTE MAXIMUM RATINGS (Note 1). PACKAGE/ORDER INFORMATION. ELECTRICAL … |
Revision | A |
File Format / Size | PDF / 270 Kb |
ABSOLUTE MAXIMUM RATINGS (Note 1). PACKAGE/ORDER INFORMATION. ELECTRICAL CHARACTERISTICS The
LTC1693
W W W U ABSOLUTE MAXIMUM RATINGS (Note 1)
Supply Voltage (VCC) .. 14V Operating Ambient Temperature Range Inputs (IN, PHASE) ... – 0.3V to 14V C-Grade ... 0°C to 70°C Driver Output ... – 0.3V to VCC + 0.3V I-Grade ..–40°C to 85°C GND1 to GND2 (Note 5) ... ±100V Storage Temperature Range ... – 65°C to 150°C Junction Temperature .. 150°C Lead Temperature (Soldering, 10 sec).. 300°C
U W U PACKAGE/ORDER INFORMATION
TOP VIEW TOP VIEW TOP VIEW IN1 1 8 VCC1 IN1 1 8 VCC1 IN 1 8 VCC GND1 2 7 OUT1 GND1 2 7 OUT1 NC 2 7 OUT IN2 3 6 V PHASE 3 6 NC CC2 IN2 3 6 VCC2 GND 4 5 NC GND2 4 5 OUT2 GND2 4 5 OUT2 MS8 PACKAGE S8 PACKAGE S8 PACKAGE 8-LEAD PLASTIC MSOP 8-LEAD PLASTIC SO 8-LEAD PLASTIC SO TJMAX = 150°C, θJA = 200°C/ W TJMAX = 150°C, θJA = 135°C/ W TJMAX = 150°C, θJA = 135°C/ W ORDER PART S8 PART ORDER PART S8 PART ORDER PART MS8 PART NUMBER MARKING NUMBER MARKING NUMBER MARKING LTC1693-1CS8 16931 LTC1693-2CS8 16932 LTC1693-3CMS8 LTEB LTC1693-1IS8 16931I LTC1693-2IS8 16932I Consult factory for Industrial and Military grade parts.
denotes specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25
C. VCC = 12V, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VCC Supply Voltage Range 4.5 13.2 V ICC Quiescent Current LTC1693-1, LTC1693-2, IN1 = IN2 = 0V (Note 2) ● 400 720 1100 µA LTC1693-3, PHASE = 12V, IN = 0V ● 200 360 550 µA ICC(SW) Switching Supply Current LTC1693-1, LTC1693-2, COUT = 4.7nF, fIN = 100kHz ● 14.4 20 mA LTC1693-3, COUT = 4.7nF, fIN = 100kHz ● 7.2 10 mA
Input
VIH High Input Threshold ● 2.2 2.6 3.1 V VIL Low Input Threshold ● 1.1 1.4 1.7 V IIN Input Pin Bias Current ● ±0.01 ±10 µA VPH PHASE Pin High Input Threshold (Note 3) ● 4.5 5.5 6.5 V IPH PHASE Pin Pull-Up Current PHASE = 0V (Note 3) ● 10 20 45 µA
Output
VOH High Output Voltage IOUT = –10mA ● 11.92 11.97 V VOL Low Output Voltage IOUT = 10mA ● 30 75 mV RONL Output Pull-Down Resistance 2.85 Ω RONH Output Pull-Up Resistance 3.00 Ω IPKL Output Low Peak Current 1.70 A IPKH Output High Peak Current 1.40 A 2
