Datasheet LTC1693 (Linear Technology) - 3
ManufacturerLinear Technology
DescriptionHigh Speed Single/Dual N-Channel MOSFET Drivers
Pages / Page20 / 3 — ELECTRICAL CHARACTERISTICS The. denotes specifications which apply over …
RevisionA
File Format / SizePDF / 270 Kb
ELECTRICAL CHARACTERISTICS The. denotes specifications which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes specifications which apply over the full operating
LTC1693
denotes specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25
C. VCC = 12V, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Switching Timing (Note 4)
tRISE Output Rise Time COUT = 1nF ● 17.5 35 ns COUT = 4.7nF ● 48.0 85 ns tFALL Output Fall Time COUT = 1nF ● 16.5 35 ns COUT = 4.7nF ● 42.0 75 ns tPLH Output Low-High Propagation Delay COUT = 1nF ● 38.0 70 ns COUT = 4.7nF ● 40.0 75 ns tPHL Output High-Low Propagation Delay COUT = 1nF ● 32 70 ns COUT = 4.7nF ● 35 75 ns
Driver Isolation
RISO GND1-GND2 Isolation Resistance LTC1693-1, LTC1693-2 GND1-to-GND2 Voltage = 75V ● 0.075 1 GΩ
Note 1:
Absolute Maximum Ratings are those values beyond which the life
Note 4:
All AC timing specificatons are guaranteed by design and are not of a device may be impaired. production tested.
Note 2:
Supply current is the total current for both drivers.
Note 5:
Only applies to the LTC1693-1 and LTC1693-2.
Note 3:
Only the LTC1693-3 has a PHASE pin.
W U TYPICAL PERFOR A CE CHARACTERISTICS IN Threshold Voltage IN Threshold Hysteresis IN Threshold Voltage vs VCC vs Temperature vs Temperature
2.75 3.00 1.4 T VCC = 12V V A = 25°C CC = 12V 2.50 2.75 1.3 V V IH IH 2.50 2.25 1.2 2.25 V 2.00 IH-VIL 2.00 1.1 1.75 1.75 1.0 1.50 V 1.50 IL INPUT THRESHOLD VOLTAGE (V) INPUT THRESHOLD VOLTAGE (V) VIL 0.9 1.25 1.25 INPUT THRESHOLD HYSTERESIS (V) 1.00 1.00 0.8 5 6 7 8 9 10 11 12 – 50 –25 0 25 50 75 100 125 – 50 – 25 0 25 50 75 100 125 VCC (V) TEMPERATURE (°C) TEMPERATURE (°C) 1693 G01 1693 G02 1693 G03 3
