Datasheet ADA4897-2-KGD (Analog Devices) - 10
Description | 1 nV/√Hz, Low Power Operational Amplifier |
Pages / Page | 10 / 10 — ADA4897-2-KGD. Known Good Die. OUTLINE DIMENSIONS. 0.483. 1.095. 10A. … |
Revision | C |
File Format / Size | PDF / 208 Kb |
ADA4897-2-KGD. Known Good Die. OUTLINE DIMENSIONS. 0.483. 1.095. 10A. 1.445. 0.070 × 0.140. TOP VIEW. SIDE VIEW. 2015-. (CIRCUIT SIDE)
ADA4897-2-KGD Known Good Die OUTLINE DIMENSIONS 0.483 1.095 10 10A 1 1A 9 9A 1.445 2 8 3 4 7 4A 5 6 A 0.070 × 0.140 TOP VIEW SIDE VIEW 2015- (CIRCUIT SIDE) 0.070 × 0.070 09- 03-
Figure 2. 10-Pad Bare Die [CHIP] (C-10-6) Dimensions shown in millimeters
DIE SPECIFICATIONS AND ASSEMBLY RECOMMENDATIONS Table 6. Die Specifications Parameter Value Unit
Scribe Line Width 75 μm Die Size (Maximum Size) 1095 × 1445 μm Thickness 483 μm Bond Pads (Minimum Size) 70 × 70 μm Bond Pad Composition 1% AlCu % Backside Si Not applicable Passivation Doped oxide/SiN Not applicable ESD HBM 2000 V
Table 7. Assembly Recommendations Assembly Component Recommendation
Die Attach Ablestik 84-1LMIS R4 Bonding Method 1 mil gold
ORDERING GUIDE Model Temperature Range Package Description Package Option
ADA4897-2-KGD –40°C to +125°C 10-Pad Bare Die [CHIP] C-10-6
©2014–2015 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. D12328-0-3/15(B)
Rev. B | Page 10 of 10 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±5 V SUPPLY +5 V SUPPLY +3 V SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS OUTLINE DIMENSIONS DIE SPECIFICATIONS AND ASSEMBLY RECOMMENDATIONS ORDERING GUIDE
