Datasheet ADA4800-KGD (Analog Devices)
Description | Low Power, High Speed CCD Buffer Amplifier |
Pages / Page | 7 / 1 — Low Power, High Speed,. CCD Buffer Amplifier. Known Good Die. … |
File Format / Size | PDF / 206 Kb |
Low Power, High Speed,. CCD Buffer Amplifier. Known Good Die. ADA4800-KGD. FEATURES. FUNCTIONAL BLOCK DIAGRAM
Low Power, High Speed, CCD Buffer Amplifier Known Good Die ADA4800-KGD FEATURES FUNCTIONAL BLOCK DIAGRAM Integrated active load and gain of 1 buffer ADA4800-KGD Very low buffer power consumption IN 1 As low as 20 mW on chip 6 ISF IISF Power save feature to reduce active load current by GPO control IBUFF High buffer speed IAL ICC 400 MHz, −3 dB bandwidth VEE 2 5 VCC +1 415 V/μs slew rate Fast settling time to 1%, 2 V step: 5 ns OUT 3 I Adjustable buffer bandwidth IDRV
1
Push-pull output stage 4 IDRV
-00 621
Adjustable active load current
15
Known Good Die (KGD): these die are fully guaranteed to
Figure 1.
data sheet specifications. APPLICATIONS CCD image sensor output buffer Digital still cameras Camcorders GENERAL DESCRIPTION
The ADA4800-KGD is voltage buffer integrated with an active The ADA4800-KGD is ideal for driving the input of the Analog load. The buffer is a low power, high speed, low noise, high slew Devices, Inc., 12-bit and 14-bit high resolution analog front ends rate, fast settling, fixed gain of 1 monolithic amplifier for charge- (AFE), such as the AD9928, the AD9990, the AD9920A, the coupled device (CCD) applications. For CCD applications, the AD9923A, and the AD9970 to AD9979 family. active load current source (IAL) can load the open source CCD The versatility of the ADA4800-KGD allows for seamless sensor outputs, and the buffer can drive the AFE load. The active interfacing with many CCD sensors from various manufacturers. current load can also be switched off to use the ADA4800-KGD as a unity-gain buffer. The buffer consumes only 20 mW of static The ADA4800-KGD operates at supply voltages as low as 4 V power. In applications where power savings is critical, the and up to 17 V. ADA4800-KGD features a power save mode that further reduces Additional application and technical information can be found the total current consumption. The bandwidth of the ADA4800- in the ADA4800 data sheet. KGD buffer is also fully adjustable through the IDRV pin. The buffer of the ADA4800-KGD employs a push-pull output stage architecture, providing drive current and maximum slew capability for both rising and falling signal transitions. At a 4.7 mA quiescent current setting, it provides 400 MHz, −3 dB bandwidth, which makes this buffer well suited for CCD sensors from machine vision to digital still camera applications.
Rev. 0 Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2017 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS BUFFER ELECTRICAL CHARACTERISTICS ACTIVE CURRENT LOAD ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TEST CIRCUIT OUTLINE DIMENSIONS DIE SPECIFICATIONS AND ASSEMBLY RECOMMENDATIONS ORDERING GUIDE
