DN3145Thermal CharacteristicsPower DissipationPackageIIDD†(continuous)†(pulsed)II@T = 25OCDRDRMA TO-243AA 100mA 300mA 1.3W ‡ 100mA 300mA Notes: † I (continuous) is limited by max rated T. D j ‡ Mounted on FR4 board, 25mm x 25mm x 1.57mm. Electrical Characteristics (T = 25OC unless otherwise specified) A SymParameterMinTypMaxUnitsConditions BV Drain-to-source breakdown voltage 450 - - V V = -5.0V, I = 100µA DSX GS D V Gate-to-source off voltage -1.5 - -3.5 V V = 15V, I = 10µA GS(OFF) DS D ΔV Change in V with temperature - - -4.5 mV/OC V = 15V, I = 10µA GS(OFF) GS(OFF) DS D I Gate body leakage current - - 100 nA V = ±20V, V = 0V GSS GS DS - - 1.0 µA V = Max rating, V = -5.0V DS GS I Drain-to-source leakage current D(OFF) - - 1.0 mA V = 0.8 Max Rating, DS V = -5.0V, T = 125OC GS A I Saturated drain-to-source current 120 - - mA V = 0V, V = 15V DSS GS DS R Static drain-to-source on-state = 0V, I = 100mA DS(ON) resistance - - 60 Ω VGS D ΔR Change in R with temperature - - 1.1 %/OC V = 0V, I = 100mA DS(ON) DS(ON) GS D G Forward transconductance 140 - - mmho V = 10V, I = 100mA FS DS D C Input capacitance - - 120 ISS V = -5.0V, GS C Common source output capacitance - - 15 pF V = 25V, OSS DS f = 1.0MHz C Reverse transfer capacitance - - 10 RSS t Turn-on delay time - - 10 d(ON) V = 25V, t Rise time - - 15 DD r ns I = 100mA, D t Turn-off delay time - - 20 d(OFF) R = 25Ω, GEN t Fall time - - 35 f V Diode forward voltage drop - - 1.8 V V = -5.0V, I = 100mA SD GS SD t Reverse recovery time - 800 - ns V = -5.0V, I = 100mA rr GS SD Notes: 1. All D.C. parameters 100% tested at 25OC unless otherwise stated. (Pulse test: 300µs pulse, 2% duty cycle.) 2. All A.C. parameters sample tested. Switching Waveforms and Test Circuit0V 90% VDDINPUTPulse R 10% Generator L -10VOUTPUT t t (ON) (OFF) RGEN t t t t d(ON) r d(OFF) f VDDINPUT 10% 10% D.U.T.OUTPUT0V 90% 90% Doc.# DSFP-DN3145 Supertex inc. A062713 2 www.supertex.com
