Datasheet LTC4310-1, LTC4310-2 (Analog Devices) - 5
Description | Hot-Swappable I2C Isolators |
Pages / Page | 20 / 5 — Typical perForMance characTerisTics. SDA, SCL Controlled Rising Edge. ICC … |
File Format / Size | PDF / 241 Kb |
Typical perForMance characTerisTics. SDA, SCL Controlled Rising Edge. ICC vs Temperature, LTC4310-1
LTC4310-1/LTC4310-2
Typical perForMance characTerisTics SDA, SCL Controlled Rising Edge ICC vs Temperature, LTC4310-1 Rate vs Temperature, LTC4310-1
5.0 2.0 SDA = 0V VCC = 5V SCL = V V CC CC = 5V 4.8 /µs) 1.8 TE (V 4.6 (mA) V 1.6 I CC CC = 3.3V 4.4 1.4 4.2 CONTROLLED RISE RA VCC = 3.3V 4.0 1.2 –50 –25 0 25 50 75 100 125 –50 –25 0 25 50 75 100 125 TEMPERATURE (°C) TEMPERATURE (°C) 431012 G01 431012 G02
SDA, SCL Controlled Rising Edge SDA, SCL Rise Time Accelerator Rate vs Temperature, LTC4310-2 Pull-Up Current vs Temperature
5.5 11 5.0 VCC = 5V 10 /µs) VCC = 5V TE (V 4.5 9 4.0 8 3.5 V 7 CC = 3.3V V PULL-UP CURRENT (mA) CC = 3.3V CONTROLLED RISE RA 3.0 6 2.5 5 –50 –25 0 25 50 75 100 125 –50 –25 0 25 50 75 100 125 TEMPERATURE (°C) TEMPERATURE (°C) 431012 G03 431012 G04
SDA, SCL Rise Time Accelerator SDA,SCL Falling Propagation Pull-Up Current vs Bus Capacitance Delay vs Temperature
12 220 TA = 25°C 10 200 VCC = 5V 8 Y (ns) 180 VCC = 3.3V 6 160 TION DELA VCC = 3.3V 4 AGA 140 VCC = 5V PULL-UP CURRENT (mA) PROP 2 120 0 0 0 100 200 300 400 500 600 700 800 –50 –25 0 25 50 75 100 125 BUS CAPACITANCE (pF) TEMPERATURE (°C) 431012 G05 431012 G06 431012fa 5 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Functional Diagram Operation Applications Information Package Description Revision History Typical Application Related Parts
