Datasheet LTC4312 (Analog Devices) - 7
Description | Pin-Selectable, 2-Channel, 2-Wire Multiplexer with Bus Buffers |
Pages / Page | 20 / 7 — BLOCK DIAGRAM |
File Format / Size | PDF / 200 Kb |
BLOCK DIAGRAM
LTC4312
BLOCK DIAGRAM
VCC VCC2 IRTA IRTA CO1 SCLOUT1 SCLIN VCC2 SLEW RATE IRTA DETECTOR 0.2V/μs CIN SLEW RATE DETECTOR V 0.2V/μs CC CO2 SCLOUT2 VCC2 IRTA IRTA MUX SDAIN DO1 SDAOUT1 V SLEW RATE DIN CC2 SLEW RATE DETECTOR DETECTOR 0.2V/μs 0.2V/μs IRTA + V CONNECT EN1 DO2 SDAOUT2 IL – EN2 + + VCC2 VIL V – LOGIC IL – 45ms TIMER + GND VIL – V UVLO 110μs CC TIMER FAULT ACC IBOOST_SCL/IBOOST_SDA DISCEN ENABLE1 ENABLE2 4314 BD 4312f 7
