LTC4318 elecTrical characTerisTicsThe l denotes the specifications which apply over the full operatingtemperature range, otherwise specifications are at TA = 25°C. VCC = 3.3V, unless otherwise specified. SYMBOLPARAMETERCONDITIONSMINTYPMAXUNITSSupply VCC Input Supply Range l 2.25 5.5 V ICC Input Supply Current ENABLE = 3.3V, SCLIN = SDAIN = 0V l 0.8 2 mA ENABLE = 0V, SCLIN = SDAIN = 0V l 350 800 µA VCC(UVLO) VCC Supply Undervoltage Lockout VCC Rising l 1.9 2.1 2.2 V VCC(HYST) VCC Supply Undervoltage Lockout Hysteresis 100 mV ENABLE and READY VENABLE(TH) ENABLE Threshold Voltage Enable Rising l 1 1.4 1.8 V VENABLE(HYST) ENABLE Hysteresis 50 mV IENABLE(LEAK) ENABLE Input Current l ±1 µA VREADY(OL) READY Output Low Voltage I = 3mA l 0.4 V IREADY(OH) READY Off Leakage Current VCC = VREADY = 5.5V l ±5 µA SCLIN, SDAIN, SCLOUT, SDAOUT VSCL,SDA(TH) Threshold Voltage SDA, SCL Pins Rising l 1.5 1.8 2.0 V VSCL,SDA(HYST) Hysteresis 50 mV ISCL,SDA(LEAK) Leakage Current SDA, SCL Pins = 5.5V, 0V, VCC = 5.5V,0V l ±10 µA ISCL,SDA(LEAK-INOUT) Input to Output Leakage Current SDAIN, SCLIN Pins = 5.5V, VCC = 5.5V, l ±10 µA SDAOUT, SCLOUT Pins = 4.5V CSCL,SDA Pin Capacitance Note 3 l 10 pF VSCL,SDA(PRE) Precharge Voltage l 0.8 1 1.2 V VSDAOUT(OL) SDAOUT Output Low Voltage I = 4mA l 0.4 V RDS(ON) Pass Switch On Resistance VCC = 2.25V, SCLIN = SDAIN = 0.4V l 3 12 Ω VCC = 3.3V, SCLIN = SDAIN = 0.4V l 2.2 8 Ω VCC = 5V, SCLIN = SDAIN = 0.4V l 1.8 6 Ω XORH, XORL IXORH/XORL XORH and XORL Input Current l ±100 nA I2C Interface Timing fSCL(MAX) Maximum SCLIN Clock Frequency Note 3 l 400 kHz tPDHL(SDAOUTn) SDAOUT Fall Delay C = 100pF, RPULLUP = 10k l 170 300 ns tf(SDAOUTn) SDAOUT Fall Time C = 100pF, RPULLUP = 10k l 20 60 300 ns tTIMEOUT Stuck Bus Timeout SCLIN Held Low or High l 25 30 35 ms tIDLE Bus Idle Time l 80 120 160 µs tGLITCH SCLIN and SDAIN Glitch Filter l 50 100 ns Note 1: Stresses beyond those listed under Absolute Maximum Ratings Note 2: All currents into pins are positive and all voltages are referenced to may cause permanent damage to the device. Exposure to any Absolute GND unless otherwise indicated. Maximum Rating condition for extended periods may affect device Note 3: Guaranteed by design and not tested. reliability and lifetime. 4318fa For more information www.linear.com/LTC4318 3
