Datasheet LTC5564 (Analog Devices) - 5
DescriptionUltraFast 7ns Response Time 15GHz RF Power Detector with Comparator
Pages / Page16 / 5 — TYPICAL PERFORMANCE CHARACTERISTICS. Supply Current vs Supply Voltage. …
File Format / SizePDF / 475 Kb
TYPICAL PERFORMANCE CHARACTERISTICS. Supply Current vs Supply Voltage. OUT vs Input Power 700 MHz. OUT vs Input Power 1.9GHz
TYPICAL PERFORMANCE CHARACTERISTICS Supply Current vs Supply Voltage OUT vs Input Power 700 MHz OUT vs Input Power 1.9GHz
LTC5564
TYPICAL PERFORMANCE CHARACTERISTICS Supply Current vs Supply Voltage V V OUT vs Input Power 700 MHz OUT vs Input Power 1.9GHz
48 4000 4800 GAIN1, GAIN2 V 3600 VCC = 5V 4400 CC = 5V 46 GAIN4, GAIN8 GAIN1 GAIN1 4000 T 3200 A = 25°C 44 3600 2800 3200 42 TAGE (mV) 2400 2800 (mA) 2000 2400 I CC 40 1600 2000 OUTPUT VOL 1600 38 1200 OUTPUT VOLTAGE (mV) –40°C 1200 V OUT 800 V OUT 25°C 36 800 400 105°C 400 125°C 34 0 0 3 3.5 4 4.5 5 5.5 –10 –8 –6 –4 –2 0 2 4 6 8 10 12 14 16 –10 –8 –6 –4 –2 0 2 4 6 8 10 12 14 16 VCC (V) RFIN POWER (dBm) RFIN POWER (dBm) 5564 G24 5564 G10 5564 G25
VOUT vs Input Power 2.7GHz VOUT vs Input Power 2.7 GHz VOUT vs Input Power 5.8 GHz
3400 3600 3200 3200 VCC = 5V V V 3000 T CC = 5V CC = 5V A = 25°C 3200 GAIN1 2800 GAIN1 –40°C 2800 2600 GAIN8 2800 –40°C 2400 2400 25°C 2200 2400 2000 2000 GAIN4 TAGE (mV) TAGE (mV) 1800 2000 25°C 1600 1600 1400 1600 1200 GAIN1 1200 OUTPUT VOLTAGE (mV) 1200 1000 OUTPUT VOL OUTPUT VOL 800 800 V OUT 800 600 V OUT 105°C V OUT GAIN2 400 125°C 400 105°C 400 200 125°C 0 0 0 –24 –20 –16 –12 –8 –4 0 4 8 12 16 –10 –8 –6 –4 –2 0 2 4 6 8 10 12 14 16 –10 –8 –6 –4 –2 0 2 4 6 8 10 12 14 16 RFIN POWER (dBm) RFIN POWER (dBm) RFIN POWER (dBm) 5564 G12 5564 G13 5564 G11
VOUT vs Input Power 8GHz VOUT vs Input Power 10GHz
2400 1600 VCC = 5V VCC = 5V GAIN1 1400 GAIN1 2000 TA = 25°C TA = 25°C 1200 1600 1000 1200 800 600 OUTPUT VOLTAGE (mV) 800 OUTPUT VOLTAGE (mV) 400 V OUT V OUT 400 200 0 0 –10 –8 –6 –4 –2 0 2 4 6 8 10 12 14 16 –24 –20 –16 –12 –8 –4 0 4 8 12 16 RFIN POWER (dBm) RFIN POWER (dBm) 5564 G26 5564 G27 5564fc For more information www.linear.com/LTC5564 5 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Simplified Block Diagram Applications Information Revision History Typical Application Related Parts
