Datasheet E522.80, E522.81, E522.82, E522.83 (Elmos) - 4
ManufacturerElmos
DescriptionTriple 150mA Linear LED Controller
Pages / Page25 / 4 — Triple. 150mA. Linear. LED. Controller. E522.80/81/82/83. Production. …
Triple. 150mA. Linear. LED. Controller. E522.80/81/82/83. Production. Data. -. May. 5,. 2017. 1. Absolute. Maximum. Ratings. Stresses. beyond. these
Triple 150mA Linear LED Controller E522.80/81/82/83 Production Data - May 5, 2017 1 Absolute Maximum Ratings Stresses beyond these
Triple 150mA Linear LED Controller E522.80/81/82/83 Production Data - May 5, 2017 1 Absolute Maximum Ratings Stresses beyond these absolute maximum ratings listed below may cause permanent damage to the device. These are stress ratings only; opera- tion of the device at these or any other conditions beyond those listed in the operational sections of this document is not implied. Exposure to absolute maximum rated conditions for extended periods may affect device reliability. All voltages referred to VGND. Currents flowing into ter- minals are positive, those drawn out of a terminal are negative. No. Description Condition Symbol Min Max Unit 1 VS Pin Voltage VVS -0.3 40 V 2 ENA Pin Voltage VENA -0.3 40 V 3 IR1,2,3 Pin Voltage 1) VIR,x -0.3 5.5 V 4 IR1,2,3 Pin Current IIR,x -1 1 mA 5 LEDx Current ILED.x -170 100 mA 6 LEDxA/B Pin Voltage VLED,x -1 VVS V 7 RUN Pin Voltage VRUN -0.3 VVS V 8 RUN Pin Current IRUN -5 5 mA 9 SLM Pin Voltage VSLM -0.3 6.5 V 10 Junction Temperature Continuous TJ -40 150 °C 11 Ambient Temperature Info Parameter 2) TA -40 125 °C 12 Storage Temperature Unsoldered Device TST -40 125 °C 13 Power Dissipation tLIFETIME < 1h PV,MAX 2.5 W 14 Thermal Resistance Junction to Exposed Die Pad 3) RTH,J-C 6 K/W 1) see parameter VIR, CLMP for clamping behaviour 2) consider maximum junction temperature and cooling measures to define ambient operating range 3) Typical thermal resistance to EP is RTH,J-C = 3K/W (not production tested) 2 ESD No. Description Condition Symbol Min Max Unit 1 ESD HBM Protection at all Pins 1) VESD,HBM -2 2 kV 2 ESD CDM Protection at Corner Pins 2) VESD,CDM,1 -750 750 V 3 ESD CDM Protection at all other Pins 2) VESD,CDM,2 -500 500 V 1) According to AEC-Q 100-002, Human Body Model, 1.5kΩ resistance, 100pF capacitance. 2) According to AEC-Q 100-011, Charged Device Model, pulse rise time (10% to 90%) <400ps, 1Ω resistance. Elmos Semiconductor AG reserves the right to change the detail specifications as may be required to permit improvements in the design of its products. Elmos Semiconductor AG Data Sheet QM-No.: 25DS0132E.03 4/25
