37 /7 — ADXL350. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. ( 30. TION. OP …
PDF / 603 Kb
ADXL350. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. ( 30. TION. OP 20. T OF P. R 10. –100. –80. –60. –40. –20. 100. ZERO g. OFFSET (mg. PER. –85. –65
ADXL350Data SheetTYPICAL PERFORMANCE CHARACTERISTICS N = 460 for all typical performance characteristics plots, unless otherwise noted. 4030))%%( 30(TION20TIONLALAUUOP 20OPT OF PT OF PNN10EECCR 10REEPP00–100–80–60–40–20020406080100 103 –100–80–60–40–20020406080100 106 ZERO gOFFSET (mg)ZERO gOFFSET (mg) 10271- 10271- Figure 4. X-Axis Zero g Offset at 25°C, V Figure 7. X-Axis Zero g Offset at 25°C, V S = 2.5 V S = 3.0 V 4030))%%( 30(TION20TIONLALAUUOP 20OPT OF PT OF PNNE10ECCR 10REEPP00–100–80–60–40–20020406080100 104 –100–80–60–40–20020406080100 107 ZERO gOFFSET (mg) 10271- ZERO gOFFSET (mg) 10271- Figure 5. Y-Axis Zero g Offset at 25°C, V Figure 8. Y-Axis Zero g Offset at 25°C, V S = 2.5 V S = 3.0 V 3030))%%((20TION20TIONAALLPUPUPOPOFFOOTT10EN10ENCCPERPER00–5153555759515–85–65–45–25110103050701–125–105–90–70–50–30–10 105 –230–210–190–170–150–130– 108 ZERO gOFFSET (mg)ZERO gOFFSET (mg) 10271- 10271- Figure 6. Z-Axis Zero g Offset at 25°C, V Figure 9. Z-Axis Zero g Offset at 25°C, V S = 2.5 V S = 3.0 V Rev. 0 | Page 6 of 36 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Absolute Maximum Ratings Thermal Resistance Package Information ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Power Sequencing Power Savings Power Modes Auto Sleep Mode Standby Mode Serial Communications SPI Preventing Bus Traffic Errors I2C Interrupts DATA_READY SINGLE_TAP DOUBLE_TAP Activity Inactivity FREE_FALL Watermark Overrun FIFO Bypass Mode FIFO Mode Stream Mode Trigger Mode Retrieving Data from FIFO Self-Test Register Map Register Definitions Register 0x00—DEVID (Read Only) Register 0x1D—THRESH_TAP (Read/Write) Register 0x1E, Register 0x1F, Register 0x20—OFSX, OFSY, OFSZ (Read/Write) Register 0x21—DUR (Read/Write) Register 0x22—Latent (Read/Write) Register 0x23—Window (Read/Write) Register 0x24—THRESH_ACT (Read/Write) Register 0x25—THRESH_INACT (Read/Write) Register 0x26—TIME_INACT (Read/Write) Register 0x27—ACT_INACT_CTL (Read/Write) ACT AC/DC and INACT AC/DC Bits ACT_x Enable Bits and INACT_x Enable Bits Register 0x28—THRESH_FF (Read/Write) Register 0x29—TIME_FF (Read/Write) Register 0x2A—TAP_AXES (Read/Write) Suppress Bit TAP_x Enable Bits Register 0x2B—ACT_TAP_STATUS (Read Only) ACT_x Source and TAP_x Source Bits Asleep Bit Register 0x2C—BW_RATE (Read/Write) LOW_POWER Bit Rate Bits Register 0x2D—POWER_CTL (Read/Write) Link Bit AUTO_SLEEP Bit Measure Bit Sleep Bit Wakeup Bits Register 0x2E—INT_ENABLE (Read/Write) Register 0x2F—INT_MAP (Read/Write) Register 0x30—INT_SOURCE (Read Only) Register 0x31—DATA_FORMAT (Read/Write) SELF_TEST Bit SPI Bit INT_INVERT Bit FULL_RES Bit Justify Bit Range Bits Register 0x32 to Register 0x37—DATAX0, DATAX1, DATAY0, DATAY1, DATAZ0, DATAZ1 (Read Only) Register 0x38—FIFO_CTL (Read/Write) FIFO_MODE Bits Trigger Bit Samples Bits 0x39—FIFO_STATUS (Read Only) FIFO_TRIG Bit Entries Bits Applications Information Power Supply Decoupling Mechanical Considerations for Mounting Tap Detection Threshold Link Mode Sleep Mode vs. Low Power Mode Offset Calibration Using Self-Test Axes of Acceleration Sensitivity Layout and Design Recommendations Outline Dimensions Ordering Guide
