Datasheet ADIS16210 (Analog Devices)
DescriptionPrecision Triaxial Inclinometer and Accelerometer with SPI
Pages / Page21 / 1 — Precision Triaxial Inclinometer and. Accelerometer with SPI. Data Sheet. …
RevisionE
File Format / SizePDF / 922 Kb
Precision Triaxial Inclinometer and. Accelerometer with SPI. Data Sheet. ADIS16210. FEATURES. GENERAL DESCRIPTION
Datasheet ADIS16210 Analog Devices, Revision: E
Precision Triaxial Inclinometer and Accelerometer with SPI Data Sheet ADIS16210 FEATURES GENERAL DESCRIPTION Triaxial, digital inclinometer system
The ADIS16210 iSensor® is a digital inclinometer system that
±180° measurement range, roll and pitch axes
provides precise measurements for both pitch and roll angles
±90° gravity axis
over a full orientation range of ±180°. It combines a MEMS tri-
±0.1° relative accuracy
axial acceleration sensor with signal processing, addressable user
Triaxial, digital accelerometer, high accuracy
registers for data collection/programming, and a SPI-compatible
±1.7 g measurement range
serial interface. In addition, the production process includes unit
±0.05° axis-to-axis alignment
specific calibration for optimal accuracy performance. It also
Digital internal temperature measurements
offers digital temperature sensor and power supply measurements
Digital internal power supply measurements
together with configuration controls for in-system calibration,
Programmable user calibration options
sample rate, filtering, alarms, I/O configuration, and power
Single command, frame alignment
management.
Manual accelerometer bias correction
The MEMS sensor elements are bound to an aluminum core for
Programmable operation and control
tight platform coupling and excellent mechanical stability. An
Sample rate/filtering
internal clock drives the data sampling system, which eliminates
Alarm conditions and indicator output
the need for an external clock source. The SPI and data buffer
Input/output: data ready, alarm, general-purpose
structure provide convenient access to accurate sensor data and
Power management functions
configuration controls.
SPI-compatible serial interface Serial number and device ID
The ADIS16210 is available in a 15 mm × 24 mm × 15 mm
Single-supply operation: 3.0 V to 3.6 V
module that provides mounting tabs with M2-sized mounting
Calibrated temperature range: −40°C to +85°C
holes and a flexible, edge terminated connector interface. It has
15 mm × 24 mm × 15 mm package with flexible connector
an extended operating temperature range of −40°C to +125°C.
APPLICATIONS Platform control, stabilization, and alignment Tilt sensing, inclinometers, and leveling Motion/position measurement Monitor/alarm devices (security, medical, safety) Navigation FUNCTIONAL BLOCK DIAGRAM DIO1 DIO2 RST VDD ADIS16210 SELF TEST I/O ALARMS POWER GND MANAGEMENT TRIAXIAL MEMS SENSOR CONTROL CS CONTROLLER REGISTERS SPI SCLK TEMPERATURE PORT SENSOR CORRECTION DIN DIGITAL INCLINE OUTPUT AND FILTER CALIBRATION REGISTERS ALIGNMENT SUPPLY DOUT
001 09593- Figure 1.
Rev. C Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. Tel: 781.329.4700 ©2011–2016 Analog Devices, Inc. All rights reserved. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS Timing Diagrams ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS BASIC OPERATION READING SENSOR DATA DEVICE CONFIGURATION USER REGISTER MAP SENSOR DATA OUTPUT DATA REGISTERS Accelerometers Inclinometers Internal Temperature Power Supply SIGNAL PROCESSING, BIAS CORRECTION, AND ALIGNMENT Digital Filtering Accelerometer/Inclinometer Resolution Accelerometer Bias Correction Gravity Vector Axis Definition Measurement Mode Two-Axis Mode User Reference Alignment SYSTEM TOOLS GLOBAL COMMANDS Software Reset User Register Save to Flash Memory Flash Memory Test Self Test Power-Down INPUT/OUTPUT FUNCTIONS Data Ready Indicator Alarm Indicator General-Purpose Input/Output DEVICE IDENTIFICATION STATUS/ERROR FLAGS FLASH MEMORY MANAGEMENT ALARMS SYSTEM ALARM STATIC ALARMS DYNAMIC ALARMS ALARM REPORTING APPLICATIONS INFORMATION INTERFACE BOARD MATING CONNECTOR OUTLINE DIMENSIONS ORDERING GUIDE
