Datasheet ADIS16210 (Analog Devices) - 2
DescriptionPrecision Triaxial Inclinometer and Accelerometer with SPI
Pages / Page21 / 2 — ADIS16210* PRODUCT PAGE QUICK LINKS Last Content Update: 09/22/2017. …
RevisionE
File Format / SizePDF / 922 Kb
ADIS16210* PRODUCT PAGE QUICK LINKS Last Content Update: 09/22/2017. COMPARABLE PARTS. DESIGN RESOURCES. EVALUATION KITS
ADIS16210* PRODUCT PAGE QUICK LINKS Last Content Update: 09/22/2017 COMPARABLE PARTS DESIGN RESOURCES EVALUATION KITS
View a parametric search of comparable parts. • ADIS16210 Material Declaration • PCN-PDN Information
EVALUATION KITS
• Quality And Reliability • ADIS16210 Daughter Board • Symbols and Footprints • ADIS16ACL1 Breakout Board • EVAL-ADIS Evaluation System
DISCUSSIONS
• EVAL-ADIS2 Evaluation System View all ADIS16210 EngineerZone Discussions.
DOCUMENTATION SAMPLE AND BUY Data Sheet
Visit the product page to see pricing options. • ADIS16210: Precision Triaxial Inclinometer and Accelerometer with SPI Data Sheet
TECHNICAL SUPPORT
Submit a technical question or find your regional support number.
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
This page is dynamically generated by Analog Devices, Inc., and inserted into this data sheet. A dynamic change to the content on this page will not trigger a change to either the revision number or the content of the product data sheet. This dynamic page may be frequently modified.
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS Timing Diagrams ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS BASIC OPERATION READING SENSOR DATA DEVICE CONFIGURATION USER REGISTER MAP SENSOR DATA OUTPUT DATA REGISTERS Accelerometers Inclinometers Internal Temperature Power Supply SIGNAL PROCESSING, BIAS CORRECTION, AND ALIGNMENT Digital Filtering Accelerometer/Inclinometer Resolution Accelerometer Bias Correction Gravity Vector Axis Definition Measurement Mode Two-Axis Mode User Reference Alignment SYSTEM TOOLS GLOBAL COMMANDS Software Reset User Register Save to Flash Memory Flash Memory Test Self Test Power-Down INPUT/OUTPUT FUNCTIONS Data Ready Indicator Alarm Indicator General-Purpose Input/Output DEVICE IDENTIFICATION STATUS/ERROR FLAGS FLASH MEMORY MANAGEMENT ALARMS SYSTEM ALARM STATIC ALARMS DYNAMIC ALARMS ALARM REPORTING APPLICATIONS INFORMATION INTERFACE BOARD MATING CONNECTOR OUTLINE DIMENSIONS ORDERING GUIDE
