Datasheet ADIS16240 (Analog Devices) - 7
DescriptionLow Power Programmable Impact Sensor and Recorder
Pages / Page21 / 7 — ADIS16240. Data Sheet. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. TOP …
RevisionC
File Format / SizePDF / 454 Kb
ADIS16240. Data Sheet. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. TOP VIEW. 1 2. 5 6 7 8. 9 10 11
ADIS16240 Data Sheet PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TOP VIEW 1 2 5 6 7 8 9 10 11
link to page 7
ADIS16240 Data Sheet PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TOP VIEW 1 2 3 4 5 6 7 8 9 10 11 A B C D E F G H J K
004
L
08133-
NOTES 1. THE ACTUAL PINS ARE NOT VISIBLE FROM THE TOP VIEW.
Figure 4. Pin Configuration (Top View)
A1 AZ X AY AY AX AX AZ
005 08133- Figure 5. Axis Orientation of Device (Top View)
Table 4. Pin Function Descriptions Pin No. Mnemonic Type1 Description
E10, E11 SCLK I SPI Serial Clock F10, F11 CS I SPI Chip Select, Active Low G10, G11 DIN I SPI Data Input H10, H11 DOUT O SPI Data Output J10, J11 DIO2 I/O Multifunction Digital Input/Output 2 K9, L9 DIO1 I/O Multifunction Digital Input/Output 1 K8, L8 AN I Analog Input Channel K7, L7 CMP2 I Analog Comparator Input 2 K6, L6 CMP1 I Analog Comparator Input 1 K3, L3 RST I Reset, Active Low, No Pull-Up Resistor J1, J2 XA O X-Axis Accelerometer Filter Pin H1, H2 YA O Y-Axis Accelerometer Filter Pin G1, G2 ZA O Z-Axis Accelerometer Filter Pin A5, B5 ST I Self-Test Input Control Line D4 to D8, E4, E8, F4, F8, G4, G8, H4 to H8 VDD S Power Supply, 3.3 V A1, A2, A10, A11, B1, B2, B10, B11, C3 to C9, D3, D9, E3, E9, F3, F9, GND S Ground G3, G9, H3, H9, J3 to J9, K1, K2, K10, K11, L1, L2, L10, L11 A3, A4, A6 to A9, B3, B4, B6 to B9, C1, C2, C10, C11, D1, D2, D10, NC No Connect D11, E1, E2, F1, F2, K4, K5, L4, L5 1 I = input, O = output, I/O = input/output, S = supply. Rev. C | Page 6 of 20 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Timing Specifications Timing Diagrams Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Sensing Element Data Sampling and Processing User Interface SPI Interface User Registers Capture Basic Operation SPI Write Commands Memory Map Output Data Registers Processing Sensor Data Event Recorder Internal Trigger Setup External Trigger Setup Buffer Memory Configuration Event Organization Reading Event Data Transient Behavior During Capture Operational Control Internal Sample Rate Global Commands Input/Output Lines Offset Adjustment Diagnostics Clock Checksum Flash Memory Endurance Management Applications Information Assembly Interface Printed Circuit Board (PCB) Outline Dimensions Ordering Guide
