Datasheet ADXL180 (Analog Devices) - 9
DescriptionConfigurable, High-g, iMEMS® Accelerometer
Pages / Page61 / 9 — ADXL180. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. VCM. VSCI. NC 1. 12 …
File Format / SizePDF / 630 Kb
ADXL180. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. VCM. VSCI. NC 1. 12 VBP. DAP1. VCM 2. 11 VCM. TOP VIEW. (Not to Scale). 10 VBN. VBN. DAP2
ADXL180 PIN CONFIGURATION AND FUNCTION DESCRIPTIONS VCM VSCI NC 1 12 VBP DAP1 VCM 2 11 VCM TOP VIEW (Not to Scale) 10 VBN VBN DAP2
ADXL180 PIN CONFIGURATION AND FUNCTION DESCRIPTIONS VCM VSCI NC NC 16 15 14 13 NC 1 12 VBP VCM DAP1 VCM 2 11 VCM ADXL180 TOP VIEW (Not to Scale) V 3 BN 10 VBN VBN DAP2 NC 4 9 VBC 5 6 7 8 VDD NC VSCO VBN
03 0 4- 54
NC = NO CONNECT
07 Figure 3. Pin Configuration
Table 4. Pin Function Descriptions Pin No. Mnemonic Description
1 NC Reserved for Analog Devices, Inc., Use Only. VBN or do not connect. 2 VCM Reserved for Analog Devices Use Only. Do not connect. 3 VBN Negative Bus Voltage. 4 NC Reserved for Analog Devices Use Only. VBN or do not connect. 5 VDD Voltage Regulator Bypass Capacitor. 6 NC Reserved for Analog Devices Use Only. VBN or do not connect. 7 VSCO Reserved for Analog Devices Use Only. Do not connect. 8 VBN Negative Bus Voltage. 9 VBC Daisy-Chain Connection. Daisy-chain connection to VBP of the second device or do not connect. 10 VBN Negative Bus Voltage. 11 VCM Reserved for Analog Devices Use Only. Do not connect. 12 VBP Positive Bus Voltage. 13 NC Reserved for Analog Devices Use Only. VBN or do not connect. 14 NC Reserved for Analog Devices Use Only. VBN or no connect 15 VSCI Analog Signal Chain Input. VBN when not in use. 16 VCM Reserved for Analog Devices Use Only. Do not connect. DAP1 VCM Exposed Pad: Reserved for Analog Devices Use Only. Do not connect. DAP2 VBN Exposed Pad: Negative Bus Voltage. Rev. A | Page 8 of 60 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TERMINOLOGY THEORY OF OPERATION OVERVIEW ACCELERATION SENSOR SIGNAL PROCESSING DIGITAL COMMUNICATIONS STATE MACHINE 2-WIRE CURRENT MODULATED INTERFACE SYNCHRONOUS OPERATION AND DUAL DEVICE BUS PROGRAMMED MEMORY AND CONFIGURABILITY Factory-Programmed Serial Number and Manufacturer Information User-Programmable Data Register User-Programmed Configuration Physical Layer (ISO Layer 1) Data Link Layer (ISO Layer 2) Application Layer (ISO Layer 7) PHYSICAL INTERFACE APPLICATION CIRCUIT CURRENT MODULATION MANCHESTER DATA ENCODING OPERATION AT LOW VBP OR LOW VDD OPERATION AT HIGH VDD COMMUNICATIONS TIMING AND BUS TOPOLOGIES DATA TRANSMISSION ASYNCHRONOUS COMMUNICATION Asynchronous Single Device Point-to-Point Topology SYNCHRONOUS COMMUNICATION Configuring the ADXL180 for Synchronous Operation Synchronization Pulse Detection Bus Discharge Enable Synchronous Single Device Point-to-Point Topology SYNCHRONOUS COMMUNICATION MODE—DUAL DEVICE Configuring Synchronous Operation Delay Selection Fixed Delay Mode Autodelay Mode Dual Device Synchronous Parallel Topology Dual Device Synchronous Series Topology DATA FRAME DEFINITION DATA FRAME TRANSMISSION FORMAT DATA FRAME CONFIGURATION OPTIONS ACCELERATION DATA CODING STATE VECTOR CODING STATE VECTOR DESCRIPTIONS TRANSMISSION ERROR DETECTION OPTIONS CRC Encoding Parity Encoding APPLICATION LAYER: COMMUNICATION PROTOCOL STATE MACHINE ADXL180 STATE MACHINE PHASE 1: POWER-ON-RESET INITIALIZATION PHASE 2: DEVICE DATA TRANSMISSION Overview Influence of MD on Data Range Device Data Mapping in Phase 2 PHASE 2: MODE DESCRIPTION Mode 0 Asynchronous Mode Synchronous Mode Mode 1 Mode 2 Device Data User Bits and User Register (UREG) 10-Bit Data and Mode 2 Mode 3 Device Data User Register (UREG) Use with State Vector Enabled Illegal Configuration: Mode 3 and 8-Bit Data PHASE 3: SELF-TEST DIAGNOSTIC Concept of Self-Test Internal and External Self-Test Option External Self-Test Internal Self-Test Influence of MD Selections On Transmitted Self-Test Data PHASE 4: AUTO-ZERO INITIALIZATION Fast Auto-Zero Mode Error Reporting PHASE 5: NORMAL OPERATION Slow Auto-Zero Error Reporting SIGNAL RANGE AND FILTERING TRANSFER FUNCTION OVERVIEW RANGE THREE-POLE BESSEL FILTER AUTO-ZERO OPERATION Offset Drift Monitoring ERROR DETECTION OVERVIEW PARITY ERROR DUE TO COMMUNICATIONS PROTOCOL CONFIGURATION BIT ERROR SELF-TEST ERROR OFFSET ERROR/OFFSET DRIFT MONITORING VOLTAGE REGULATOR MONITOR RESET OPERATION TEST AND DIAGNOSTIC TOOLS VSCI SIGNAL CHAIN INPUT TEST PIN VSCO ANALOG SIGNAL CHAIN OUTPUT TEST PIN CONFIGURATION SPECIFICATION OVERVIEW CONFIGURATION MODE TRANSMIT COMMUNICATIONS PROTOCOL CONFIGURATION MODE COMMAND (RECEIVE) COMMUNICATIONS PROTOCOL CONFIGURATION MODE COMMUNICATIONS HANDSHAKING CONFIGURATION AND USER DATA REGISTERS CONFIGURATION MODE EXIT SERIAL NUMBER AND MANUFACTURER IDENTIFICATION DATA REGISTERS PROGRAMMING THE CONFIGURATION AND USER DATA REGISTERS OTP PROGRAMMING CONDITIONS AND CONSIDERATIONS CONFIGURATION/USER REGISTER OTP PARITY CONFIGURATION MODE ERROR REPORTING CONFIGURATION REGISTER REFERENCE UD[7:0] USER DATA BITS UD8 CONFIGURATION BIT BDE SCOE FDLY ADME STI FC[1:0] RG[2:0] MD[1:0] SYEN AZE ERC DAT SVD CUPAR AND CUPRG AXIS OF SENSITIVITY BRANDING OUTLINE DIMENSIONS ORDERING GUIDE
