Datasheet ADIS16203 (Analog Devices) - 9
Description | Programmable 360° Inclinometer |
Pages / Page | 29 / 9 — ADIS16203. TYPICAL PERFORMACE CHARACTERISTICS. ree. O TI. INCL. –1.0. … |
Revision | C |
File Format / Size | PDF / 459 Kb |
ADIS16203. TYPICAL PERFORMACE CHARACTERISTICS. ree. O TI. INCL. –1.0. –0.8. –0.6 –0.4. –0.2. 0.2. 0.4. 0.6. 0.8. 1.0. 2.9. 3.0. 3.1. 3.2. 3.3. 3.4. 3.5. 3.6. 3.7
ADIS16203 TYPICAL PERFORMACE CHARACTERISTICS 30 90 25 80 70 ) 20 ) % s ( 60 N ree O TI eg 15 D 50 LA ( U T P U 40 O _O P 10 30 INCL 5 20 10 0
2
–1.0 –0.8 –0.6 –0.4 –0.2 0 0.2 0.4 0.6 0.8 1.0
03
0
8-
2.9 3.0 3.1 3.2 3.3 3.4 3.5 3.6 3.7
08 0
ERROR (Degrees)
10 8- 06
SUPPLY (V)
10 06 Figure 5. Inclination Error Distribution at 25°C/3.3 V, Incline = 0° Figure 8. Self-Test Shift vs. Supply at 25°C
150 3.5 3.0 125 2.5 100 ) s 2.0 Y ree IT eg 1.5 75 D ( UANT T U Q 1.0 _O 50 0.5 INCL 0 25 –0.5 0 6 8 0 2 4 6 8 0 2 4 6 8 0 2 4 6 8 0 2 4 6 8 0 2 4 –1.0 –40 –20 0 20 40 60 80 100 120
06 09 0
607. 607. 608. 608. 608. 608. 608. 609. 609. 609. 609. 609. 610. 610. 610. 610. 610. 611. 611. 611. 611. 611. 612. 612. 612.
0 8- 8-
TEMPERATURE (°C)
10
(µV/LSB)
610 06 0 Figure 6. Inclination Error vs. Temperature Figure 9. ADC Gain Distribution at 25°C/3.3 V
80 0.40 70 0.35 60 0.30 50 0.25 rees) TY g e TI D N 40 ( 0.20 A R U O Q R 30 R 0.15 E ± 20 0.10 10 0.05 0 0 .4 .1 .8 .5 .2 .9 .6 .3 0 3 6 9 2 5 8 1 4 7 0 3 6 9 2 5 8
3
2.9 3.0 3.1 3.2 3.3 3.4 3.5 3.6 3.7 0. 0. 0. 1. 1. 1. 2. 2. 2. 3. 3. 3. 3. 4. 4. 4.
10 03
–2 –2 –1 –1 –1 –0 –0 –0
0 8- 8-
SUPPLY VOLTAGE (V)
10
(mV)
10 06 06 Figure 7. Inclination Error vs. Supply Figure 10. ADC Offset Distribution at 25°C/3.3 V Rev. A | Page 8 of 28 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS TIMING DIAGRAMS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMACE CHARACTERISTICS THEORY OF OPERATION OUTPUT RESPONSE TEMPERATURE SENSOR BASIC OPERATION SERIAL PERIPHERAL INTERFACE (SPI) DATA OUTPUT REGISTER ACCESS PROGRAMMING AND CONTROL CONTROL REGISTER OVERVIEW CONTROL REGISTER ACCESS CONTROL REGISTER DETAILS CALIBRATION CALIBRATION REGISTER DEFINITION INCL_NULL Register Definition ALARMS ALM_MAG1 Register Definition ALM_SMPL1 Register Definition ALM_MAG2 Register Definition ALM_SMPL2 Register Definition ALM_CTRL Register Definition SAMPLE PERIOD CONTROL SMPL_TIME Register Definition FILTERING CONTROL AVG_CNT Register Definition POWER-DOWN CONTROL SLP_CNT Register Definition STATUS FEEDBACK STATUS Register Definition COMMAND CONTROL COMMAND Register Definition MISCELLANEOUS CONTROL REGISTER MSC_CTRL Register Definition PERIPHERALS AUXILIARY ADC FUNCTION AUXILIARY DAC FUNCTION AUX_DAC Register Definition GENERAL-PURPOSE I/O CONTROL GPIO_CTRL Register Definition APPLICATIONS HARDWARE CONSIDERATIONS GROUNDING AND BOARD LAYOUT RECOMMENDATIONS SELF-TEST TIPS BAND GAP REFERENCE POWER-ON RESET OPERATION SECOND-LEVEL ASSEMBLY EXAMPLE PAD LAYOUT OUTLINE DIMENSIONS ORDERING GUIDE
