Datasheet ADIS16201 (Analog Devices)
Description | Programmable Dual-Axis Inclinometer/Accelerometer |
Pages / Page | 33 / 1 — Programmable Dual-Axis. Inclinometer/Accelerometer. Data Sheet. … |
Revision | E |
File Format / Size | PDF / 605 Kb |
Programmable Dual-Axis. Inclinometer/Accelerometer. Data Sheet. ADIS16201. FEATURES. FUNCTIONAL BLOCK DIAGRAM
![Datasheet ADIS16201 Analog Devices, Revision: E](https://www.rlocman.ru/datasheet/img.php?di=130223)
Programmable Dual-Axis Inclinometer/Accelerometer Data Sheet ADIS16201 FEATURES FUNCTIONAL BLOCK DIAGRAM Dual-axis inclinometer/accelerometer measurements AUX AUX ADC DAC VREF 12-, 14-bit digital inclination/acceleration sensor outputs ±1.7 g accelerometer measurement range ADIS16201 ±90° inclinometer measurement range, linear output TEMPERATURE SENSOR 12-bit digital temperature sensor output Digitally controlled sensitivity and bias calibration DUAL-AXIS CS ACCELEROMETER SIGNAL CALIBRATION CONDITIONING AND Digitally controlled sample rate AND DIGITAL SCLK CONVERSION PROCESSING SPI Digitally controlled frequency response PORT DIN Dual alarm settings with rate/threshold limits DIGITAL SELF-TEST DOUT Auxiliary digital I/O CONTROL Digitally activated self test Digitally activated low power mode VDD POWER AUXILIARY ALARMS SPI®-compatible serial interface MANAGEMENT I/O Auxiliary 12-bit ADC input and DAC output COM Single-supply operation: 3.0 V to +3.6 V
001
3500 g powered shock survivability RST DIO0 DIO1
05462- Figure 1.
APPLICATIONS Platform control, stabilization, and leveling Tilt sensing, inclinometers Motion/position measurement Monitor/alarm devices (security, medical, safety) GENERAL DESCRIPTION
The ADIS16201 is a complete, dual-axis acceleration and The ADIS16201 offers the fol owing embedded features, which inclination angle measurement system available in a single eliminate the need for external circuitry and provide a simplified compact package enabled by the Analog Devices iSensor™ system interface: integration. By enhancing the Analog Devices iMEMS® sensor • technology with an embedded signal processing solution, the Configurable alarm function ADIS16201 provides factory calibrated and tunable digital • Auxiliary 12-bit ADC sensor data in a convenient format that can be accessed using a • Auxiliary 12-bit DAC serial peripheral interface (SPI). The SPI interface provides access to measurements for dual-axis linear acceleration, dual- • Configurable digital I/O port axis linear inclination angle, temperature, power supply, and • Digital self-test function one auxiliary analog input. Easy access to calibrated digital sensor data provides developers with a system-ready device, The ADIS16201 offers two power management features for reducing development time, cost, and program risk. managing system-level power dissipation: low power mode and a configurable shutdown feature. Unique characteristics of the end system are accommodated easily through several built-in features, such as a single The ADIS16201 is available in a 9.2 mm × 9.2 mm × 3.9 mm command in-system offset calibration, along with convenient laminate-based land grid array (LGA) package with a sample rate and bandwidth control. temperature range of −40°C to +125°C.
Rev. C Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. Tel: 781.329.4700 ©2006–2013 Analog Devices, Inc. All rights reserved. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Timing Specifications Timing Diagrams Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Accelerometer Operation Inclinometer Operation Temperature Sensor Basic Operation Data Output Register Access Programming and Control Control Register Overview Control Register Access Control Register Details Calibration Calibration Register Definitions XACCL_OFF Register Definition XACCL_SCALE Register Definition YACCL_OFF Register Definition YACCL_SCALE Register Definition XINCL_OFF Register Definition XINCL_SCALE Register Definition YINCL_OFF Register Definition YINCL_SCALE Register Definition Alarms ALM_MAG1 Register Definition ALM_SMPL1 Register Definition ALM_MAG2 Register Definition ALM_SMPL2 Register Definition ALM_CTRL Register Definition Sample Period Control SMPL_PRD Register Definition Filtering Control AVG_CNT Register Definition Power-Down Control PWR_MDE Register Definition Status Feedback STATUS Register Definition Command Control COMMAND Register Definition Miscellaneous Control Register MSC_CTRL Register Definition Peripherals Auxiliary ADC Function Auxiliary DAC Function AUX_DAC Register Definition General Purpose I/O Control GPIO_CTRL Register Definition Applications Serial Peripheral Interface (SPI) Hardware Considerations Grounding and Board Layout Recomendations Bandgap Reference Power-On Reset Operation Second-Level Assembly Example Pad Layout Outline Dimensions Ordering Guide
