Datasheet ADIS16201 (Analog Devices) - 10
DescriptionProgrammable Dual-Axis Inclinometer/Accelerometer
Pages / Page33 / 10 — Data Sheet. ADIS16201. 140. 120. 100. TITY. –1. –0. (g). (Degrees). –200 …
RevisionE
File Format / SizePDF / 605 Kb
Data Sheet. ADIS16201. 140. 120. 100. TITY. –1. –0. (g). (Degrees). –200 –160 –120. –80. –40. 160. 200. (ppm/°C). 1200. 1000. T (. 800. OFFS. EST. TION. 600. LIN. SEL
Data Sheet ADIS16201 140 120 100 TITY –1 –0 (g) (Degrees) –200 –160 –120 –80 –40 160 200 (ppm/°C) 1200 1000 T ( 800 OFFS EST TION 600 LIN SEL
Data Sheet ADIS16201 90 140 80 120 70 100 60 50 80 TITY TITY N N A A 40 60 QU QU 30 40 20 20 10 0 0 2 1 0 9 8 7 6 5 4 3 2 1 0 1 2 3 4 5 6 7 8 9 0 1 2 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 0. 0. 0. 0. 0. 0. 0. 0. 0. 1. 1. 1. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0. 0.
011
–1. –1. –1. –0. –0. –0. –0. –0. –0. –0. –0. –0.
014
(g) (Degrees)
05462- 05462- Figure 11. X-Axis Self-Test Level at 25°C/3.3 V Figure 14. Inclination Offset Distribution at 25°C/3.3 V/0 g
80 20 18 70 16 60 14 50 12 TITY TITY N 40 N 10 A A QU QU 8 30 6 20 4 10 2 0 0 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 –200 –160 –120 –80 –40 0 40 80 120 160 200
015
012
(ppm/°C)
05462-
(g)
05462- Figure 12. Y-Axis Self-Test Level at 25°C/3.3 V Figure 15. Inclination Offset Tempco Histogram at 3.3 V
1200 10 8 1000 ) 6 B ) LS 4 SB T ( (L E T 800 2 IF SH OFFS 0 EST TION –2 -T 600 A F LIN –4 SEL C IN 400 –6 –8 200 –10 2.9 3.0 3.1 3.2 3.3 3.4 3.5 3.6 3.7 2.9 3.0 3.1 3.2 3.3 3.4 3.5 3.6 3.7
016 013
POWER SUPPLY (V) POWER SUPPLY (V)
05462- 05462- Figure 13. Self-Test Shift vs. Supply at 25°C Figure 16. Inclination Offset vs. Supply at 25°C Rev. C | Page 9 of 32 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Timing Specifications Timing Diagrams Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Accelerometer Operation Inclinometer Operation Temperature Sensor Basic Operation Data Output Register Access Programming and Control Control Register Overview Control Register Access Control Register Details Calibration Calibration Register Definitions XACCL_OFF Register Definition XACCL_SCALE Register Definition YACCL_OFF Register Definition YACCL_SCALE Register Definition XINCL_OFF Register Definition XINCL_SCALE Register Definition YINCL_OFF Register Definition YINCL_SCALE Register Definition Alarms ALM_MAG1 Register Definition ALM_SMPL1 Register Definition ALM_MAG2 Register Definition ALM_SMPL2 Register Definition ALM_CTRL Register Definition Sample Period Control SMPL_PRD Register Definition Filtering Control AVG_CNT Register Definition Power-Down Control PWR_MDE Register Definition Status Feedback STATUS Register Definition Command Control COMMAND Register Definition Miscellaneous Control Register MSC_CTRL Register Definition Peripherals Auxiliary ADC Function Auxiliary DAC Function AUX_DAC Register Definition General Purpose I/O Control GPIO_CTRL Register Definition Applications Serial Peripheral Interface (SPI) Hardware Considerations Grounding and Board Layout Recomendations Bandgap Reference Power-On Reset Operation Second-Level Assembly Example Pad Layout Outline Dimensions Ordering Guide
