Datasheet ADIS16201 (Analog Devices) - 9
Description | Programmable Dual-Axis Inclinometer/Accelerometer |
Pages / Page | 33 / 9 — ADIS16201. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 140. ) g. … |
Revision | E |
File Format / Size | PDF / 605 Kb |
ADIS16201. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 140. ) g. 2.174. 120. B S L. 2.170. ( Y. 100. IT IV. 2.165. 2.161. N A. N S. 2.157. RAT E
ADIS16201 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 140 ) g 2.174 /m 120 B S L 2.170 ( Y 100 IT IV 2.165 IT TY 80 NS TI E 2.161 N A N S U 60 IO 2.157 Q RAT E 40 L 2.153 CE AC 2.148 20 2.144 0 2.9 3.0 3.1 3.2 3.3 3.4 3.5 3.6 3.7
05 0 2-
8 7 5 4 2 1 0 2 3 5 6 8 9 –9 –8 –6 –5 –3 –2 11 12 14 15 17 18
08
POWER SUPPLY (V)
46
–1 –1 –1 –1 –1 –1
0 05
2-
(mg)
46 05 Figure 5. Acceleration Sensitivity vs. Power Supply at 25°C Figure 8. Acceleration Offset Distribution at 25°C/3.3 V/0 g
25 20 18 20 16 14 15 Y 12 TY IT TI N 10 A ANT U U Q 10 Q 8 6 5 4 2 0 0 –150 –120 –90 –60 –30 0 30 60 90 120 150
06 09 0
–200 –160 –120 –80 –40 0 40 80 120 160 200
0 2- 2-
(ppm/°C)
46
(ppm/°C)
46 05 05 Figure 6. Acceleration Sensitivity Tempco Histogram at 3.3 V Figure 9. Acceleration Offset Tempco Histogram at 3.3 V
2.192 50 ) g 40 m 2.183 B/ 30 S B) L S ( L Y 2.175 ( T 20 IT E IV S F 10 IT 2.166 F NS E N O 0 IO N S 2.158 –10 IO T RAT E L RA E –20 E 2.149 L CE ACC –30 2.141 AC –40 2.132 –50 –60 –40 –20 0 20 40 60 80 100 120 140
07 10 0
0 2- 2-
TEMPERATURE (°C)
46 46 05
POWER SUPPLY (V)
05 Figure 7. Acceleration Sensitivity vs. Temperature at 3.3 V Figure 10. Acceleration Offset vs. Supply at 25°C Rev. C | Page 8 of 32 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Timing Specifications Timing Diagrams Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Accelerometer Operation Inclinometer Operation Temperature Sensor Basic Operation Data Output Register Access Programming and Control Control Register Overview Control Register Access Control Register Details Calibration Calibration Register Definitions XACCL_OFF Register Definition XACCL_SCALE Register Definition YACCL_OFF Register Definition YACCL_SCALE Register Definition XINCL_OFF Register Definition XINCL_SCALE Register Definition YINCL_OFF Register Definition YINCL_SCALE Register Definition Alarms ALM_MAG1 Register Definition ALM_SMPL1 Register Definition ALM_MAG2 Register Definition ALM_SMPL2 Register Definition ALM_CTRL Register Definition Sample Period Control SMPL_PRD Register Definition Filtering Control AVG_CNT Register Definition Power-Down Control PWR_MDE Register Definition Status Feedback STATUS Register Definition Command Control COMMAND Register Definition Miscellaneous Control Register MSC_CTRL Register Definition Peripherals Auxiliary ADC Function Auxiliary DAC Function AUX_DAC Register Definition General Purpose I/O Control GPIO_CTRL Register Definition Applications Serial Peripheral Interface (SPI) Hardware Considerations Grounding and Board Layout Recomendations Bandgap Reference Power-On Reset Operation Second-Level Assembly Example Pad Layout Outline Dimensions Ordering Guide
