link to page 8 Data SheetADIS16201PIN CONFIGURATION AND FUNCTION DESCRIPTIONSADCEFMDD VAUXVRCO13141516AUX DAC 121SCLKADIS16201BOTTOMNC 11VIEW2DOUT(Not to Scale)AUX COM 103DINORX SENSORRST9Y SENSOR4CS8765NC = NO INTERNALMNCCONNECTIONIO1IO0CODD 004 AUX 05462- Figure 4. Pin Configuration Table 5. Pin Function Descriptions Pin No.MnemonicType1Description 1 SCLK I Serial Clock. SCLK provides the serial clock for accessing data from the part and writing serial data to the control registers. 2 DOUT O Data Out. The data on this pin represents data being read from the control registers and is clocked out on the falling edge of the SCLK. 3 DIN I Data In. Data written to the control registers is provided on this input and is clocked in on the rising edge of the SCLK. 4 CS I Chip Select, Active Low. This input frames the serial data transfer. 5, 6 DIO0, DIO1 I/O Multifunction Digital I/O Pins. 7, 11 NC – No Connect. 8, 10 AUX COM S Auxiliary Grounds. Connect to GND for proper operation. 9 RST I Reset, Active Low. This input resets the embedded microcontroller to a known state. 12 AUX DAC O Auxiliary DAC Analog Voltage Output. 13 VDD S +3.3 V Power Supply. 14 AUX ADC I Auxiliary ADC Analog Input Voltage. 15 VREF O Precision Reference Output. 16 COM S Common. Reference point for all circuitry in the ADIS16201. 1 S = Supply; O = Output; I = Input. Rev. C | Page 7 of 32 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Timing Specifications Timing Diagrams Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Accelerometer Operation Inclinometer Operation Temperature Sensor Basic Operation Data Output Register Access Programming and Control Control Register Overview Control Register Access Control Register Details Calibration Calibration Register Definitions XACCL_OFF Register Definition XACCL_SCALE Register Definition YACCL_OFF Register Definition YACCL_SCALE Register Definition XINCL_OFF Register Definition XINCL_SCALE Register Definition YINCL_OFF Register Definition YINCL_SCALE Register Definition Alarms ALM_MAG1 Register Definition ALM_SMPL1 Register Definition ALM_MAG2 Register Definition ALM_SMPL2 Register Definition ALM_CTRL Register Definition Sample Period Control SMPL_PRD Register Definition Filtering Control AVG_CNT Register Definition Power-Down Control PWR_MDE Register Definition Status Feedback STATUS Register Definition Command Control COMMAND Register Definition Miscellaneous Control Register MSC_CTRL Register Definition Peripherals Auxiliary ADC Function Auxiliary DAC Function AUX_DAC Register Definition General Purpose I/O Control GPIO_CTRL Register Definition Applications Serial Peripheral Interface (SPI) Hardware Considerations Grounding and Board Layout Recomendations Bandgap Reference Power-On Reset Operation Second-Level Assembly Example Pad Layout Outline Dimensions Ordering Guide
