Datasheet ADIS16006 (Analog Devices) - 10
DescriptionDual-Axis ±5 g Accelerometer with SPI Interface
Pages / Page17 / 10 — Data Sheet. ADIS16006. 250. AVG AT 5.25V. AVG AT 5.00V. 200. (% N IO. AVG …
RevisionC
File Format / SizePDF / 290 Kb
Data Sheet. ADIS16006. 250. AVG AT 5.25V. AVG AT 5.00V. 200. (% N IO. AVG AT 4.75V. 150. T F. AVG AT 3.60V. 100. AVG AT 3.30V. E C. AVG AT 3.00V. PER
Data Sheet ADIS16006 250 AVG AT 5.25V AVG AT 5.00V 200 (% N IO AVG AT 4.75V 150 T F AVG AT 3.60V 100 AVG AT 3.30V E C AVG AT 3.00V PER
Data Sheet ADIS16006 45 250 AVG AT 5.25V 40 ) AVG AT 5.00V 200 35 (% N IO 30 ) T AVG AT 4.75V A SB L 150 25 (L PU ST PO E F 20 T F AVG AT 3.60V O 100 L T E AVG AT 3.30V N 15 S E C 10 AVG AT 3.00V PER 50 5 0 0 80 85 90 95 100 105 110 115 120 125 130 135 140
13 16 0
–50 0 50 100 150
0 5- 5-
NOISE (µg / Hz)
97
TEMPERATURE (°C)
97 05 05 Figure 13. Noise (Y-Axis) at VCC = 5 V, 25°C Figure 16. Self-Test X-Axis vs. Temperature
40 250 AVERAGE = 202.2137 STANDARD DEVIATION = 12.09035 230 35 +125°C ) 210 (% 30 N 190 IO ) T +25°C A 25 SB L 170 (L PU –40°C 20 ST 150 PO E F T F O 130 15 L T E N S E 110 C 10 PER 90 5 70 0 50
7
110 130 150 170 190 210 230 250 270 290
14 0
3.0 3.5 4.0 4.5 5.0 5.5
5- -01
OUTPUT (LSB)
97
V
75 05
CC (V)
059 Figure 14. X-Axis Self-Test at VCC = 5 V, 25°C Figure 17. Self-Test X-Axis vs. Supply Voltage
40 1.8 AVERAGE = 82.89281 STANDARD DEVIATION = 4.908012 +125°C 35 1.7 ) (% 30 N 1.6 A) IO T m +25°C A 25 ( 1.5 L NT PU 20 RRE 1.4 PO F CU O Y –40°C 15 T L 1.3 N P E P C U 10 S 1.2 PER 5 1.1 0 1.0 40 45 50 55 60 65 70 75 80 85 90 95 100 105 110
15 0 8
5- -01
OUTPUT (LSB)
97 75 05
VCC (V)
059 Figure 18. Supply Current vs. Supply Voltage Figure 15. X-Axis Self-Test at VCC = 3.3 V, 25°C Rev. C | Page 9 of 16 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Timing Specifications Circuit and Timing Diagrams Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Accelerometer Data Format Self-Test Serial Interface Accelerometer Serial Interface Accelerometer Control Register Power-Down ADD0 ZERO ONE DONTC Accelerometer Conversion Details Temperature Sensor Serial Interface Read Operation Write Operation Temperature Sensor Control Register ZERO Output Data Format Temperature Sensor Conversion Details Power Supply Decoupling Setting the Bandwidth Selecting Filter Characteristics: The Noise/Bandwidth Trade-Off Applications Second Level Assembly Outline Dimensions Ordering Guide
