Datasheet ADXL213 (Analog Devices) - 6
DescriptionLow Cost ±1.2g Dual Axis Accelerometer
Pages / Page13 / 6 — ADXL213. TYPICAL PERFORMANCE CHARACTERISTICS (VS = 5 V for all graphs, …
RevisionA
File Format / SizePDF / 218 Kb
ADXL213. TYPICAL PERFORMANCE CHARACTERISTICS (VS = 5 V for all graphs, unless otherwise noted.). 25.0. 20.0. 15.0. LATION (%). 10.0
ADXL213 TYPICAL PERFORMANCE CHARACTERISTICS (VS = 5 V for all graphs, unless otherwise noted.) 25.0 20.0 15.0 LATION (%) 10.0
ADXL213 TYPICAL PERFORMANCE CHARACTERISTICS (VS = 5 V for all graphs, unless otherwise noted.) 25.0 25.0 20.0 20.0 15.0 15.0 LATION (%) LATION (%) U U P P O O 10.0 10.0 NT OF P NT OF P RCE RCE E 5.0 E 5.0 P P 0
04742-0-002
0
04742-0-005
43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 DUTY CYCLE OUTPUT (%) DUTY CYCLE OUTPUT (%)
Figure 3. X Axis Zero g Bias Deviation from Ideal at 25°C Figure 6. Y Axis Zero g Bias Deviation from Ideal at 25°C
30.0 40.0 35.0 25.0 30.0 20.0 25.0 LATION (%) LATION (%) U U P P O 15.0 O 20.0 15.0 NT OF P 10.0 NT OF P RCE RCE 10.0 E E P 5.0 P 5.0 0
04742-0-003
0
04742-0-006
0 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 –1.0 –0.9 –0.8 –0.7 –0.6 –0.5 –0.4 –0.3 –0.2 –0.1 –1.0 –0.9 –0.8 –0.7 –0.6 –0.5 –0.4 –0.3 –0.2 –0.1 TEMPCO (mg /°C) TEMPCO (mg /°C)
Figure 4. X Axis Zero g Bias Tempco Figure 7. Y Axis Zero g Bias Tempco
30.0 30.0 25.0 25.0 ) ) % % ( ( 20.0 20.0 TION TION LA LA 15.0 15.0 OF POPU OF POPU T T N 10.0 N 10.0 E E C C PER 5.0 PER 5.0 0
04742-0-004
0
04742-0-007
28.0 28.4 28.8 29.2 29.6 30.0 30.4 30.8 31.2 31.6 32.0 28.0 28.4 28.8 29.2 29.6 30.0 30.4 30.8 31.2 31.6 32.0 DUTY CYCLE OUTPUT (% per g ) DUTY CYCLE OUTPUT (% per g )
Figure 5. X Axis Sensitivity at 25°C Figure 8. Y Axis Sensitivity at 25°C Rev. A | Page 5 of 12 Document Outline REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION PERFORMANCE APPLICATIONS POWER SUPPLY DECOUPLING SETTING THE BANDWIDTH USING CX AND CY SELF TEST DESIGN TRADE-OFFS FOR SELECTING FILTER CHARACTERISTICS: THE NOISE/BW TRADE-OFF USING THE ADXL213 WITH OPERATING VOLTAGES OTHER THAN 5 V USING THE ADXL213 AS A DUAL-AXIS TILT SENSOR Dual-Axis Tilt Sensor: Converting Acceleration to Tilt PIN CONFIGURATIONS AND FUNCTIONAL DESCRIPTIONS OUTLINE DIMENSIONS ESD CAUTION ORDERING GUIDE AUTOMOTIVE PRODUCTS
