Datasheet AD652 (Analog Devices) - 2
DescriptionMonolithic Synchronous Voltage-to-Frequency Converter
Pages / Page29 / 2 — AD652* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionC
File Format / SizePDF / 640 Kb
AD652* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. DISCUSSIONS. DOCUMENTATION. SAMPLE AND BUY
AD652* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS DISCUSSIONS DOCUMENTATION SAMPLE AND BUY
View a parametric search of comparable parts. View all AD652 EngineerZone Discussions.
DOCUMENTATION SAMPLE AND BUY Application Notes
Visit the product page to see pricing options. • AN-276: Analog to Digital Conversion by Using V/F Converters
TECHNICAL SUPPORT Data Sheet
Submit a technical question or find your regional support • AD652: Monolithic Synchronous Voltage-to-Frequency number. Converter Data Sheet • AD652: Military Data Sheet
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
DESIGN RESOURCES
• AD652 Material Declaration • PCN-PDN Information • Quality And Reliability • Symbols and Footprints
Document Outline FEATURES PRODUCT DESCRIPTION PRODUCT HIGHLIGHTS FUNCTIONAL BLOCK DIAGRAM SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION DEFINITIONS OF SPECIFICATIONS THEORY OF OPERATION OVERRANGE SVFC CONNECTION FOR DUAL SUPPLY, POSITIVE INPUT VOLTAGES SVFC CONNECTIONS FOR NEGATIVE INPUT VOLTAGES SVFC CONNECTION FOR BIPOLAR INPUT VOLTAGES PLCC CONNECTIONS GAIN AND OFFSET CALIBRATION GAIN PERFORMANCE REFERENCE NOISE DIGITAL INTERFACING CONSIDERATIONS COMPONENT SELECTION DIGITAL GROUND SINGLE-SUPPLY OPERATION FREQUENCY-TO-VOLTAGE CONVERTER DECOUPLING AND GROUNDING FREQUENCY OUTPUT MULTIPLIER SINGLE-LINE MULTIPLEXED DATA TRANSMISSION Multiplexer Transmitter SVFC Demultiplexer Analog Signal Reconstruction ISOLATED FRONT END A-TO-D CONVERSION DELTA MODULATOR BRIDGE TRANSDUCER INTERFACE OUTLINE DIMENSIONS ORDERING GUIDE
