AD650Data SheetAD650J/AD650AAD650K/AD650BAD650SModelMinTypMaxMinTypMaxMinTypMaxUnits AMPLIFIER OUTPUT (F/V CONVERSION) Voltage Range (1500 Ω Min Load Resistance) 0 10 0 10 0 10 V Source Current (750 Ω Max Load Resistance) 10 10 10 mA Capacitive Load (Without Oscillation) 100 100 100 pF POWER SUPPLY Voltage, Rated Performance ±9 ±18 ±9 ±18 ±9 ±18 V Quiescent Current 888 mA TEMPERATURE RANGE Rated Performance N Package 0 +70 0 +70 °C D Package −25 +85 −25 +85 −55 +125 °C 1 Nonlinearity is defined as deviation from a straight line from zero to ful scale, expressed as a fraction of full scale. 2 Full-scale calibration error adjustable to zero. 3 Measured at full-scale output frequency of 100 kHz. 4 Refer to F/V conversion section of the text. 5 Referred to digital ground. Specifications shown in boldface are tested on al production units at final electrical test. Results from those tests are used to calculate outgoing quality levels. All min and max specifications are guaranteed, although only those shown in boldface are tested on all production units. Rev. E | Page 4 of 20 Document Outline Features Functional Block Diagram Product Description Product Highlights Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Circuit Operation Unipolar Configuration One-Shot Timing Component Selection Bipolar V/F Unipolar V/F, Negative Input Voltage F/V Conversion High Frequency Operation Decoupling and Grounding Temperature Coefficients Nonlinearity Specification PSRR Other Circuit Considerations Applications Differential Voltage-to-Frequency Conversion Autozero Circuit Phase-Locked Loop F/V Conversion Outline Dimensions Ordering Guide
