Datasheet ICM7242 (Intersil) - 10
ManufacturerIntersil
DescriptionLong Range Fixed Timer
Pages / Page11 / 10 — Dual-In-Line Plastic Packages (PDIP). E8.3 (JEDEC MS-001-BA ISSUE D). 8 …
Revision2017-11-02
File Format / SizePDF / 579 Kb
Dual-In-Line Plastic Packages (PDIP). E8.3 (JEDEC MS-001-BA ISSUE D). 8 LEAD DUAL-IN-LINE PLASTIC PACKAGE. INDEX. 1 2 3. N/2
Dual-In-Line Plastic Packages (PDIP) E8.3 (JEDEC MS-001-BA ISSUE D) 8 LEAD DUAL-IN-LINE PLASTIC PACKAGE INDEX 1 2 3 N/2
ICM7242
Dual-In-Line Plastic Packages (PDIP) E8.3 (JEDEC MS-001-BA ISSUE D) N 8 LEAD DUAL-IN-LINE PLASTIC PACKAGE E1 INDEX 1 2 3 N/2 INCHES MILLIMETERS AREA SYMBOL MIN MAX MIN MAX NOTES -B-
A - 0.210 - 5.33 4
-A- D E
A1 0.015 - 0.39 - 4
BASE
A2 0.115 0.195 2.93 4.95 -
PLANE A2 -C- A
B 0.014 0.022 0.356 0.558 -
SEATING PLANE L CL
B1 0.045 0.070 1.15 1.77 8, 10
D1 A e 1 A
C 0.008 0.014 0.204 0.355 -
D1 B1 e e C C
D 0.355 0.400 9.01 10.16 5
B eB
D1 0.005 - 0.13 - 5
0.010 (0.25) M C A B S
E 0.300 0.325 7.62 8.25 6 NOTES: E1 0.240 0.280 6.10 7.11 5 1. Controlling Dimensions: INCH. In case of conflict between e 0.100 BSC 2.54 BSC - English and Metric dimensions, the inch dimensions control. 2. Dimensioning and tolerancing per ANSI Y14.5M
1982. eA 0.300 BSC 7.62 BSC 6 3. Symbols are defined in the “MO Series Symbol List” in Section eB - 0.430 - 10.92 7 2.2 of Publication No. 95. L 0.115 0.150 2.93 3.81 4 4. Dimensions A, A1 and L are measured with the package seated N 8 8 9 in JEDEC seating plane gauge GS
3. 5. D, D1, and E1 dimensions do not include mold flash or protru- Rev. 0 12/93 sions. Mold flash or protrusions shall not exceed 0.010 inch (0.25mm). 6. E and eA are measured with the leads constrained to be per- pendicular to datum -C- . 7. eB and eC are measured at the lead tips with the leads uncon- strained. eC must be zero or greater. 8. B1 maximum dimensions do not include dambar protrusions. Dambar protrusions shall not exceed 0.010 inch (0.25mm). 9. N is the maximum number of terminal positions. 10. Corner leads (1, N, N/2 and N/2 + 1) for E8.3, E16.3, E18.3, E28.3, E42.6 will have a B1 dimension of 0.030 - 0.045 inch (0.76 - 1.14mm). FN2866 Rev 5.00 Page 10 of 11 September 14, 2015
