Datasheet ICM7555, ICM7556 (Intersil) - 9 Manufacturer Intersil Description General Purpose Timers Pages / Page 13 / 9 — link. to. page. 3. link. to. page. 1. link. to. page. 2. ICM7555,. … Revision 2017-11-27 File Format / Size PDF / 420 Kb Document Language English
link. to. page. 3. link. to. page. 1. link. to. page. 2. ICM7555,. ICM7556. Revision. History. The. revision. history. provided. is. for. informational. purposes. only
Model Line for this Datasheet Text Version of Document link to page 3 link to page 1 link to page 2 ICM7555, ICM7556 Revision History The revision history provided is for informational purposes only and is believed to be accurate, but not warranted. Please go to the web to make sure that you have the latest revision. DATE REVISION CHANGE June 28, 2016 FN2867.10 Converted to new datasheet template. Updated 14 Ld PDIP “Pin Configuration” on page 1 by adding “1” or “2” to pins that have same name. Updated “Thermal Information” on page 3 by removing Maximum Lead Temperature and Adding TJC values with corresponding note. Updated “Ordering Information” table on page 2 by removing obsoleted parts, adding Tape and Reel option column, adding MSL note and numbering notes accordingly. Updated POD M8.15 to most current version. POD changes are as follows: Changed in Typical Recommended Land Pattern the following: 2.41(0.095) to 2.20(0.087) 0.76 (0.030) to 0.60(0.023) 0.200 to 5.20(0.205) Updated to new POD format by removing table and moving dimensions onto drawing and adding land pattern About Intersil Intersil Corporation is a leading provider of innovative power management and precision analog solutions. The company's products address some of the largest markets within the industrial and infrastructure, mobile computing and high-end consumer markets. For the most updated datasheet, application notes, related documentation and related parts, please see the respective product information page found at www.intersil.com. You may report errors or suggestions for improving this datasheet by visiting www.intersil.com/ask. Reliability reports are also available from our website at www.intersil.com/support. © Copyright Intersil Americas LLC 1997-2016. All Rights Reserved. All trademarks and registered trademarks are the property of their respective owners. For additional products, see www.intersil.com/en/products.html Intersil products are manufactured, assembled and tested utilizing ISO9001 quality systems as noted in the quality certifications found at www.intersil.com/en/support/qualandreliability.html Intersil products are sold by description only. Intersil may modify the circuit design and/or specifications of products at any time without notice, provided that such modification does not, in Intersil's sole judgment, affect the form, fit or function of the product. Accordingly, the reader is cautioned to verify that datasheets are current before placing orders. Information furnished by Intersil is believed to be accurate and reliable. However, no responsibility is assumed by Intersil or its subsidiaries for its use; nor for any infringements of patents or other rights of third parties which may result from its use. No license is granted by implication or otherwise under any patent or patent rights of Intersil or its subsidiaries. For information regarding Intersil Corporation and its products, see www.intersil.com FN2867 Rev 1.00 Page 9 of 13 June 28, 2016
