Datasheet AMP03 (Analog Devices)
Description | Precision, Unity-Gain Differential Amplifier Data Sheet |
Pages / Page | 9 / 1 — Precision, Unity-Gain. Differential Amplifier. AMP03. FEATURES. … |
Revision | F |
File Format / Size | PDF / 292 Kb |
Precision, Unity-Gain. Differential Amplifier. AMP03. FEATURES. FUNCTIONAL BLOCK DIAGRAM
a
Precision, Unity-Gain Differential Amplifier AMP03 FEATURES FUNCTIONAL BLOCK DIAGRAM High CMRR: 100 dB Typ Low Nonlinearity: 0.001% Max AMP03 Low Distortion: 0.001% Typ 25k
25k
Wide Bandwidth: 3 MHz Typ –IN 2 5 SENSE Fast Slew Rate: 9.5 V/
s Typ Fast Settling (0.01%): 1
s Typ 7 +VCC Low Cost 6 OUTPUT APPLICATIONS Summing Amplifiers 4 –VEE Instrumentation Amplifiers Balanced Line Receivers 25k
25k
+IN 3 1 REFERENCE Current-Voltage Conversion Absolute Value Amplifier 4 to 20 mA Current Transmitter Precision Voltage Reference Applications PIN CONNECTIONS Lower Cost and Higher Speed Version of INA105 8-Lead PDIP (P Suffix) GENERAL DESCRIPTION
The AMP03 is a monolithic unity-gain, high speed differential
REFERENCE 1 8 NC AMP03
amplifier. Incorporating a matched thin film resistor network,
–IN 2 7 V+ TOP VIEW
the AMP03 features stable operation over temperature without
+IN 3 (Not to Scale) 6 OUTPUT
requiring expensive external matched components. The AMP03
V– 4 5 SENSE
is a basic analog building block for differential amplifier and
NC = NO CONNECT
instrumentation applications.
8-Lead SOIC
The differential amplifier topology of the AMP03 both amplifies the difference between two signals and provides extremely high
(S Suffix)
rejection of the common-mode input voltage. By providing common-mode rejection (CMR) of 100 dB typical, the AMP03
solves common problems encountered in instrumentation design.
–IN 2 7 V+ TOP VIEW
As an example, the AMP03 is ideal for performing either addi-
tion or subtraction of two signals without using expensive
V– 4 5 SENSE
externally matched precision resistors. The large common-mode
NC = NO CONNECT
rejection is made possible by matching the internal resistors to better than 0.002% and maintaining a thermally symmetric
Header
layout. Additionally, due to high CMR over frequency, the
(J Suffix)
AMP03 is an ideal general amplifier for buffering signals in a noisy environment into data acquisition systems.
NC 8
The AMP03 is a higher speed alternative to the INA105.
REFERENCE 1 7 V+
Featuring slew rates of 9.5 V/µs and a bandwidth of 3 MHz, the AMP03 offers superior performance to the INA105 for high
–IN 2 6 OUTPUT
speed current sources, absolute value amplifiers, and summing amplifiers.
+IN 3 5 SENSE 4 V– NC = NO CONNECT
REV. F Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. No license is granted by implication or otherwise
under any patent or patent rights of Analog Devices. Trademarks and
Tel: 781/329-4700 www.analog.com
registered trademarks are the property of their respective owners.
Fax: 781/326-8703 © 2003 Analog Devices, Inc. All rights reserved.
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PIN CONNECTIONS SPECIFICATIONS WAFER TEST LIMITS ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE DICE CHARACTERISTICS BURN-IN CIRCUIT SLEW RATE TEST CIRCUIT Typical Performance Characteristics APPLICATION CIRCUITS APPLICATIONS INFORMATION MAINTAINING COMMON-MODE REJECTION OUTLINE DIMENSIONS Revision History
