Datasheet AMP03 (Analog Devices) - 5
Description | Precision, Unity-Gain Differential Amplifier Data Sheet |
Pages / Page | 9 / 5 — AMP03–Typical Performance Characteristics. 120. 0.1. 110. A = +25. TA = … |
Revision | F |
File Format / Size | PDF / 292 Kb |
AMP03–Typical Performance Characteristics. 120. 0.1. 110. A = +25. TA = +25. VS =. 15V. 100. AV = –1. 0.010. RL = 600. THD+N (%). 0.001. RL = 100k
AMP03–Typical Performance Characteristics 120 0.1 T 110 A = +25
ⴗ
C TA = +25
ⴗ
C VS =
ⴞ
15V VS =
ⴞ
15V 100 AV = –1 90 80 0.010 70 RL = 600
60 50 THD+N (%) 40 0.001 30 RL = 100k
20 COMMON-MODE REJECTION (dB) 10 0 0.0001 1 10 100 1k 10k 100k 1M 20 100 1k 10k 20k FREQUENCY (Hz) FREQUENCY (Hz)
TPC 1. Small Signal Transient TPC 2. Common-Mode Rejection TPC 3. Total Harmonic Distortion Response vs. Frequency vs. Frequency
120 0.1 T T 110 A = +25
ⴗ
C A = +25
ⴗ
C VS =
ⴞ
15V VS =
ⴞ
15V 100 AV = –1 90 80 –PSRR 0.010 70 60 RL = 600
, 100k
50 DIM (%) +PSRR 40 0.001 30 20 POWER SUPPLY REJECTION (dB) 10 0 0.0001 1 10 100 1k 10k 100k 1M 2k 10k 50k FREQUENCY (Hz) FREQUENCY (Hz)
TPC 4. Large Signal Transient TPC 5. Power Supply Rejection vs. TPC 6. Dynamic Intermodulation Response Frequency Distortion vs. Frequency
1000 10 V 50 S =
ⴞ
15V TA = +25°C 800 TA = +25°C 40 VS =
ⴞ
15V V) VS =
ⴞ
15V
600 8 30 )
400 20 6 200 10 0 4 –200 0 –400 –10 INPUT OFFSET VOLTAGE ( CLOSED-LOOP GAIN (dB) OUTPUT IMPEDANCE ( 2 –600 –20 –800 0 –75 –50 –25 0 25 50 75 100 125 150 –30100 1k 10k 100k 1M 10M 100 1k 10k 100k 1M TEMPERATURE (
ⴗ
C) FREQUENCY (Hz) FREQUENCY (Hz)
TPC 7. Input Offset Voltage vs. TPC 8. Closed-Loop Gain vs. TPC 9. Closed-Loop Output Temperature Frequency Impedance vs. Frequency –4– REV. F Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PIN CONNECTIONS SPECIFICATIONS WAFER TEST LIMITS ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE DICE CHARACTERISTICS BURN-IN CIRCUIT SLEW RATE TEST CIRCUIT Typical Performance Characteristics APPLICATION CIRCUITS APPLICATIONS INFORMATION MAINTAINING COMMON-MODE REJECTION OUTLINE DIMENSIONS Revision History
